23694 Discussions
Intel arc 580 driver installation issue
akashmondol
drivers does not install .got this problem.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
akashmondol
here is the file
AlHill
You have "AMD Ryzen 5 5600G with Radeon Graphics"
I do not see any Intel graphics or ARC add-on card.
