22657 Discusiones
Intel arc b580 big fps drops in monster Hunter Wild
RemyBoyz
Novato
4.595 Vistas
I upgraded from a rtx 2060 super to the b580 and I'm getting constant frame drops.
Example in 1080p 60 fps to 13fps or even 2fps
I don't have very many games but I have tested gta5 and only experienced small barely noticeable frame drops. I have had no problems in apex Legends
I have used DDU multiple times
resize bar is enabled I have tried the two newest drivers. Bios is up to date
Specs
CPU i3 13100f
RAM 32gb 3600mhz
Power Supply 850W
GPU GUNNIR Intel arc B580
Etiquetas (1)
0 kudos
1 Solución
RemyBoyz
Novato
4.453 Vistas
I have included clips and a SSU file. The clips go from lowest graphical settings to the highest using Intel XeSS
I have tried intel drivers 101.6632   101.6651   101.6653   101.6732 and they still had the issue.
but so far the latest Driver 32.0.101.6734 seems to have fix the problem.
Thank You
Ver la solución en mensaje original publicado
8 Respuestas
JohnM_Intel
Moderador
4.541 Vistas
Hello RemyBoyz,
Thank you for reaching out to our community and for sharing the detailed steps you’ve already taken, including using DDU, enabling ReBar, and updating to the latest drivers. To further investigate the issue, I have a few questions for you:
  1. Which driver versions have you tried so far?
  2. What is your current installed driver version?
  3. Could you share the in-game settings you’re using for Monster Hunter: Wilds?
Looking forward to your response!
John Sergio M.
VonM_Intel
Moderador
4.492 Vistas
Hello RemyBoyz,
Von M.
RemyBoyz
Novato
4.488 Vistas
Sorry i didn't get notified of your message. As it is 11pm for me i will get you all of the info you need in the morning thank you
VonM_Intel
Moderador
4.469 Vistas
Hello RemyBoyz,
No worries at all, I completely understand. Thank you for letting me know. Please take your time, and feel free to provide the information whenever it’s convenient for you in the morning. I’ll be here to assist you whenever you're ready.
Have a great evening, and I look forward to hearing from you soon.
Von M.
RemyBoyz
Novato
4.454 Vistas
Thank You
VonM_Intel
Moderador
4.304 Vistas
Hello RemyBoyz,
I appreciate you for providing the video clips and the SSU file, as well as for detailing the steps you've taken in troubleshooting the issue. I truly appreciate the time and effort you've dedicated to testing multiple driver versions and documenting your findings so thoroughly. It’s great to hear that the latest driver version 32.0.101.6734 appears to have resolved the problem. Your feedback is incredibly valuable, and it helps us continue to improve the performance and stability of our drivers.
In the meantime, as the latest driver version appears to have resolved the issue, may I kindly confirm if we can proceed with closing this thread?
Von M.
RemyBoyz
Novato
4.300 Vistas
Yep feel free to close the thread and i appreciate your time and assistance
Thank you Von
VonM_Intel
Moderador
4.292 Vistas
Hello RemyBoyz,
Thank you for your swift response and for the confirmation, and I truly appreciate your kind words. I appreciate you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, I will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel.
Have a great day!
Von M.
Responder
