My Razer Blade 15 Advanced (Mid 2021) RZ09-0409 and many other Intel machines will not wake from sleep when using Intel driver 31.0.101.5074 or newer (including 31.0.101.5085).
Steps to reproduce:
- install any Intel 31.0.101.5*** driver
- restart once the install completes
- from desktop, set your machine to sleep mode
- wake the machine from sleep
Results:
The machine wakes up from sleep (fans spinning, keyboard lights up), but the screen is completely black (not even backlight).
Expected behaviour:
The machine should wake from sleep normally, being fully operational.
Note: Intel driver 31.0.101.4972 (and older) works as expected, with no problems. This is a problem introduced in the 31.0.101.5*** driver branch.
Machine configuration: Intel i7-11800H, RTX 3080, Windows 10 21h2
slash, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
Albert R.
I will attach the report.
slash, Thank you very much for providing the SSU report.
Based on the information shown in the SSU document, we can confirm that the graphics driver version currently installed on your computer is 31.0.101.5085. Which, as you described, is provided by Intel®.
For this scenario, it is important to mention that the Intel® graphics drivers are generic. We always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform, especially in this case that the device is working with a dual graphics configuration.
I looked on Razer's website but I was not able to find the graphics driver, just a BIOS update:
So, I will do further research on this matter to try to find a possible solution for this scenario. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Hello slash, I just received an update on this matter.
After reviewing the case, we would like to let you know that we were unable to replicate the issue using the latest drivers 31.0.101.5085 and 31.0.101.5122
Since we did not see this issue on the latest version, please, as the last recommendation from our side, try a clean driver installation using DDU:
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
If the issue remains after that as we cannot replicate the issue the next thing to do will be to get in contact directly with Razer Support for further assistance on this matter:
https://www.razer.com/contact-us
Albert R.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
