23261 Discussions
Intel driver update 15.28.23.64.4101 wont install?
cthor4
Hi all, hoping for some help.
Recently turned my desktop back on after about 2 years off. Running through all the updates im stuck with the one for my driver.
I have the Intel driver update utility installed and its finding the update 15.28.23.64.4101 (9.17.10.4101), under the "older drivers" tab.
Go through with download/install then once it gets to the page stating the computer now requires to restart, the update utility page shows it has failed. The computer restarts then im back where I started with it stating I need to update still.
Any suggestions?
Thank you.
Hello coreythorny,
I will be more than glad to assist you with your concern.
Could you please provide me with the model of your laptop, desktop or motherboard?
Could you please confirm the model of your processor?
As soon as you reply I will continue working with your concern.
Angie
cthor4
Hi there,
Thank you for your reply.
It is a Advent DT1410 with Windows 7 X64
The processor is an intel i5-2320.
Hello coreythorny,
Thanks for your reply.
With this information, I will continue with the investigation of your case.
I will let you know, as soon as I have further details.
Thank you for your patience.
Angie.
Hello coreythorny,
In regard to your concern, you can try to complete a manual installation of the latest graphic driver for your Intel® Core™ i5-2320 Processor (Intel® HD Graphics 2000).
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*
https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81502 Intel® HD Graphics Driver for Windows* 7/8-64-bit (Version: 15.28.24.64.4229 (Latest) Date: 6/5/2015)
Please bear in mind, the driver or software for your Intel® component might have been changed or replaced by the computer manufacturer. We recommend you work with your computer manufacturer(OEM) before installing our driver so you don't lose features or customizations.
If the issue persists after you try to install our drivers, please try to install the drivers provided by your OEM.
http://www.adventcomputers.co.uk/product-download-select/58 ADVENT DT1404 or DT1410 Drivers/Downloads
And if you will need additional technical assistance, you can go to:
http://www.adventcomputers.co.uk/forums/updates-drivers-and-maintenance Advent Technical Support (Updates, drivers, and maintenance Forum)
I am looking forward to hearing from you.
Angie
Hello coreythorny,
I was reviewing this thread and I would like to know if you were able to install the graphics driver.
Please do not hesitate in replying to this post in case you need further assistance.
Juan Carlos
