23063 Discussions
Intel driver updater says no drivers detected
mhey
It says no drivers found since when I downloaded Driver Booster I'm unable to play Minecraft due to an error about my graphics driver to outdated.
I'm running windows 10 and my log file for the driver updater is
DriverUpdateUI.exe Information: 0 : Log File Created 10/23/2015 8:06:12 PM
DriverUpdateUI.exe Information: 0 : Driver Manager: 10/23/2015 Running an Autodetect on Microsoft Windows* 10 Home, 64-bit with build 2.2.0.5
DriverUpdateUI.exe Information: 0 : Intel Board is False
DriverUpdateUI.exe Information: 0 : Calling IDUUDetection.IDUUDetection().getDriverData with 63 driverInfos
DriverUpdateUI.exe Information: 0 : IDUU-Detection: HW signature count = 63
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A16
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0412
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0416
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A1E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A2E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D22
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_161E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0887
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0888
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_088E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_088F
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0F31
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0152
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0156
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0162
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0166
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0402
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0406
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_016A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A06
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A0E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_040A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_22B0
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_22B1
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_015A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - EN_8086&DEV_0A06
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B3
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B4
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B1
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B2
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_095A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_095B
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_3165
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_3166
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Beginning detection at 8:23:56 PM
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Finished detection at 8:23:56 PM
DriverUpdateUI.exe Information: 0 : IDUUDetection.IDUUDetection().getDriverData returned true
DriverUpdateUI.exe Information: 0...
mhey
Then could I get it's download cause when I upgraded it worked, now since I got that program that upgrades graphics drivers it doesn't work no more. When I also downloaded Windows 10 it gave me a warning that it wasn't compatible with Windows 10 but I hit continue anyway and it worked till I downloaded that program.
Amy_C_Intel
I understand your situation but given fact this that processor is not supported under Windows® 10 it leaves you depending on Windows Updates for any driver releases, unfortunately from our end this is the far as we can go.
Amy.
mhey
So is it possible putting the driver I had as to when I first installed windows 10 where it was supported? Or what do I do in this case uninstall windows 10?
Amy_C_Intel
You will be able to get driver through Windows Updates if you installed Windows® 10. That would be the only way to get update graphics drivers for your operating system. On the Intel download page, there are no plans for Windows 10 updates for your graphics controller.
Amy.
mhey
Then how was it that it used to work, and do you think Microsoft will be able to help further since it's more on their system update side and since I uninstalled the graphics driver will it still be able to detect that it's my intel graphics card for future intel graphics system update?
Amy_C_Intel
Intel does not have plans to develop drivers for Windows® 10 for graphics controller. You will have to rely on Windows Updates for graphics drivers, as mentioned before this is the far as we can go. The fact that the driver worked is matter out of our scope, you can check official documentation stating that this graphics controller is not supported for Windows 10 and you can also note from the https://downloadcenter.intel.com/ Intel® Download Center there are not drivers for this graphics controller to work with Windows 10.
Regards.
JOrla1
I have the same problem and nobody help me with that... This app never worked fine to me.
mhey
Did you also use that program which updates your graphics that messed up mine?
KSchu3
The same thing is happening to me I have played a few games who have told me to update my drivers so I'm always recommended to this app but it always tells me it doesn't detect drivers.
