22963 Discussions
Intel driver updater says no drivers detected
mhey
It says no drivers found since when I downloaded Driver Booster I'm unable to play Minecraft due to an error about my graphics driver to outdated.
I'm running windows 10 and my log file for the driver updater is
DriverUpdateUI.exe Information: 0 : Log File Created 10/23/2015 8:06:12 PM
DriverUpdateUI.exe Information: 0 : Driver Manager: 10/23/2015 Running an Autodetect on Microsoft Windows* 10 Home, 64-bit with build 2.2.0.5
DriverUpdateUI.exe Information: 0 : Intel Board is False
DriverUpdateUI.exe Information: 0 : Calling IDUUDetection.IDUUDetection().getDriverData with 63 driverInfos
DriverUpdateUI.exe Information: 0 : IDUU-Detection: HW signature count = 63
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A16
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0412
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0416
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_041E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A1E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A2E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D22
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0D26
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_161E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0887
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0888
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_088E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_088F
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0F31
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0152
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0156
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0162
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0166
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0402
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0406
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_016A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A06
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_0A0E
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_040A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_22B0
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_22B1
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_015A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - EN_8086&DEV_0A06
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B3
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B4
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B1
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_08B2
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_095A
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_095B
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_3165
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Signature - VEN_8086&DEV_3166
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Beginning detection at 8:23:56 PM
DriverUpdateUI.exe Information: 0 : IDUU-Detection: Finished detection at 8:23:56 PM
DriverUpdateUI.exe Information: 0 : IDUUDetection.IDUUDetection().getDriverData returned true
DriverUpdateUI.exe Information: 0...
Amy_C_Intel
Hello manylol's,
Could you please let us know the driver version and the Minecraft version that you're running?
Amy.
mhey
Latest Minecraft version in Minecraft it says the error is regarding this. How do I find the version of my driver?
Amy_C_Intel
Run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility. This utility automatically identifies the computer components, operating system, and driver versions you have on your computer, once is done please attached the file here.
For further reference http://www.intel.com/support/software/applications/ssu/sb/CS-035779.htm Intel® System Support Utility — Intel® System Support Utility (Intel® SSU) Frequently Asked Questions.
Amy.
mhey
It says no drivers of your products were detected I only have a log file.
Amy_C_Intel
Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
If you can attach the file created with the System Support Utility that will be helpful in order to narrow the issue.
Amy.
Amy_C_Intel
Try with the following driver https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen].
If the issue persists attach the information requested previously.
mhey
Well I downloaded the file but how do I install the driver?
Amy_C_Intel
Follow these instructions http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*.
mhey
Driver version doesn't change.
Amy_C_Intel
Follow these instructions http://www.intel.com/support/graphics/sb/CS-034574.htm Graphics Drivers — Uninstalling the Intel® Graphics Driver and Intel Display/HDMI Audio Driver and try to install the driver one more time with the manual installation.
If the the version does not change on the device manager, this is an issue related with Windows registry.
mhey
this happens when uninstalling the graphics driver looks like http://prntscr.com/91lcfe http://prntscr.com/91lcfe i right click the controller one under the display adapters to install my graphics card but it say some error occurred http://prntscr.com/91ldfp http://prntscr.com/91ldfp
Amy_C_Intel
Could please let us know your computer model?
mhey
gateway NE56R running Windows 10.
gbhj
on the details tab select hardware ids then you can look to see what driver supports that GPU
mhey
where do i find the details tab?
mhey
Oh, no it only shows the one which is currently enabled, since I had to uninstall it it shows one that isn't Intel's it is from Microsoft
gbhj
the hardware ids will be the same
mhey
It's not showing me the Intel one ever since I was told to remove it and reinstall it.
Amy_C_Intel
Checking the specifications of your system, I noticed that your processor; Intel® Pentium® Processor B960 belongs to the second generation of processors meaning that from our site there are no drivers available for Windows® 10 since it's no supported under that operating system, note the picture below;
That is reason why when you try to run the Intel® Driver Update Utility it gives you a pop up stating that "No drivers were detected for you product.". At this stage you will be able to download the driver through Windows Updates.
For further reference http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems.
Regards.
