23762 Discussions
Intel graphic HD 530
UElim
hi,
I have a problem installing the latest update of my Intel graphic HD 530.
I am running windows 10 enterprise 64-bit version 1803 with intel core i7-6700HQ 2.6GHZ.
While I am trying to install the latest update I get an error message with:
"The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer.
Setup will exit."
When I go to my computer manufacturer site it says that they don't know this update and even the previous update for this hardware.
I want to link my laptop to a second screen but the resolution on the second screen is awful and I know that the second screen supports these resolutions.
The connection between my laptop and the second screen is via HDMI cable.
Can someone help me with that?
Stefan3D
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
Stefan3D
UElim
Thanks a lot, Stefan.
Fix the installation disability but didn't fix my real problem.
Hello, urielimelech.
Can you please describe the issue you are facing?
Antony S.
I would like to know if you still need assistance?
Antony S.
UElim
sorry Antony.
For now eveything is ok.
thanks
zaynsal
Hello @intel,
I have an issue that my screen laptop just crashed + turned off and restart again directly when or after login the windows. However, I can get into the safety mode and disable the Graphics 530 and reboot into regular mode, then it works properly, but the feedback is nonadjustable brightness of screen. My laptop has a GTX965m and an Intel Graphics 530. I also get latest windows update
and bios update. I've tried a lot of version of driver, includes the recommended version from my "Multi-com" Laptop and last updates on windows but its happen even if I  installed from there . By the way, this problem happen a year ago and I installed windows 11 but still the same issue happen over and over again .
Disable = no brightness adjustment,
Enable = crash and turn off and restart again with no reason when or I m on trying to login the windows couple seconds without doing anything its happen (web, games, etc)
Anyone could help please you ll be my hero for real
Laptop information:
the laptop is multi-com
Intel Core i7-6700HQ
GTX965m / Intel Graphics 530​
System manufacturer:notebook
version 10.0.19045 structure 19045
The manufacturer of the system Microsoft
System name: DESKTOP-RQ9N15H
System model: N15_N17RF1
Type of system : x64-based PC
BIOS version/date: American Mega trends Inc 1.05.02, 01-04-2016
BIOS System Management version of: 3.0
The version of the controller: 255.255
BIOS mode: U.E.F.I
windows information >>
Windows 10 Pro version
Version 22h2
Installed on 29-02-2024
OS architecture 19045.4170
Windows Feature Experience Pack 1000.19054.1000.0
