22680 ディスカッション
Intel graphic scaling option went missing
LGeeC
ビギナー
3,101件の閲覧回数
Hello, my intel graphic scaling option went missing out of a sudden... I used to play games by using 4:3 stretched screen which is annoying me... Anyone one can help me out? Thanks
0 件の賞賛
6 返答(返信)
Silos_ben
ビギナー
3,072件の閲覧回数
I have the same problem.
It used to look like this:
and since the newest update 08/30/20 to the command center it now looks like this:
Maria_R_Intel
モデレーター
3,057件の閲覧回数
Hello @Silos_ben ,
Thank you for your post.
Please, let us know if you are using the same system as LGeec, we are currently working on this but keep in mind that he has a laptop, and third-party systems can work different, so if it is not the same we encourage you to open a new thread so we can assist you with more accurate support depending on your system.
Maria R.
Maria_R_Intel
モデレーター
3,059件の閲覧回数
Hello LGeeC,
Thank you for posting on the Intel* Community.
To better assist you, please provide us the below information:
  • By any chance, did you complete a driver/Windows* update on your system? If so, please provide details.
  • Provide me the version of the Intel* Graphics Command Center you're using. (Check this on the IGCC >Support >System Diagnostic)
  • I am able to see in the picture the scaling option and the aspect ratio, can you please provide more details about the issue?
Provide the Intel* Graphics Command Center report:
>Go to the Intel Graphics Command Center
>Support
>System Diagnostic
>Generate report.
>Attach the report file.
Maria R.
Maria_R_Intel
モデレーター
2,980件の閲覧回数
Hello, LGeeC, Silos_ben,
I checked this internally, and definitely, the Intel* Graphics Command Center changed.
The "Scale" option is still available.
If you are using the Recommended Screen Resolution for the selected display then you will only see 'Maintain Display Scaling'. The 'Custom' scaling option will also be available just in case you need to correct any overscan. The remaining scaling options (Centered, Stretched, and Maintain Aspect Ratio) will be revealed when using a screen resolution different than the maximum supported resolution or recommended for the selected display.
So, basically, you just have to change the resolution to one different to the 'Recommended Screen Resolution' and then you will see the options available.
Maria R.
Maria_R_Intel
モデレーター
2,947件の閲覧回数
Hello LGeeC,
Let me know if you need more assistance.
Maria R.
Maria_R_Intel
モデレーター
2,928件の閲覧回数
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
返信
