23269 Discussions
Intel i3-9100 4k output lagging?
sserj1
I recently bought an intel i3-9100. I found out that the screen is lagging when running on https://snaptube.cam/ 4k output 9apps but everything is fine when running on other resolution. I have the latest update of the driver for UHD graphics 630 and all the setting are correct.
Seem like UHD graphics 630 can only support HEVC on 2k resolution only. Is there any fix?
jhold7
hi
yes
Will core i3 9100f with 710 GPU be able to play 4k hdr 10 videos ... iGPU, so in this case the GT710 is mandatory to get any video output at all.
AlHill
"so in this case the GT710 is mandatory to get any video output at all."
That is not what the OP asked.
Doc
Esteban_D_Intel
Hello sserj1,
Thank you for posting on the Intel® communities.
To better assist you I would like to gather some information about your system.
Please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU)
Intel® SSU Download link
  1. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  2. Click on the menu where it says "Summary" to change to "Detailed View".
  3. To save your scan, click on "Next", then "Save".
Esteban D.
Intel Technical Support Technician
Esteban_D_Intel
Were you able to check the previous post?
Let me know if you need more assistance.
Esteban D.
Esteban_D_Intel
We have not heard back from you, so we will close this inquiry.
If you need further assistance, please post a new question.
Esteban D.
