22664 Diskussionen
Inter HD Graphic 2500 error with Cinema 4D
aahme20
Einsteiger
8.068Aufrufe
Hello there!
i just start learning Cinema 4D and i'm facing a problem with the Graphic ..
when i run the program i get an error after 10-15 minutes it says please check your graphic driver ...
i'm using:
main board: Intel DH77KC
Processor i5-3330
RAM 12 GB
intel HD Graphics 2500
any suggestion how to get rid of this ?
15 Antworten
Mitarbeiter
6.052Aufrufe
Hello abkamd,
Could you please let me know your operating system, and the driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Amy.
aahme20
Einsteiger
6.052Aufrufe
Hi intel_corp
here is the details,
The driver details as u can see in the attached image,
the Driver version: 10.18.10.4358
and i'm using Windows 8.1 64-bit
thanks..^^
aahme20
Einsteiger
6.052Aufrufe
i've just updated to windows 10, but still i'm getting the same problem
Mitarbeiter
6.052Aufrufe
Please try updating the current driver version to the latest version which is .4425. Here you can find the file; https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33], and I recommend this method for the installation; http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows....
Let me know how that goes.
Amy.
aahme20
Einsteiger
6.052Aufrufe
Hello intel_corp
sorry for my delay, I had a connection problem ..
i have updated the Driver to .4425 but unfortunately still getting the same issue ..
Mitarbeiter
6.052Aufrufe
/thread/109740 abkamd, please let me review your thread, as soon as I have more information I will update the thread.
Amy.
Mitarbeiter
6.052Aufrufe
/thread/109740 abkamd, thank you for your patience.
Since you already tried the latest driver from our end, the next step would be reporting this issue to MAXON for further debugging. If you notice there is bugreport message in your screenshot, that is the file you should take to MAXON for review;
See here for the contact information; https://www.maxon.net/en/support/how-can-we-help/ How can we help? - MAXON | 3D FOR THE REAL WORLD .
Amy.
Mitarbeiter
6.052Aufrufe
/thread/109740 abkamd, let me know if you get in contact with MAXON.
Amy.
aahme20
Einsteiger
6.052Aufrufe
intel_corp hi,
sorry for my delay .. actually I'm facing a problem with my connection these days ..
yup actually I hv contacted them but unfortunately they didn't solve the problem for me .. but they mentioned ( Be aware, that this kind of graphiccard is not recommended to run Cinema 4D.)
maybe I need to get another graphic card ..^^
Thanks Mr. Amy for ur help and assistance ..
aahme20
Einsteiger
6.052Aufrufe
intel_corp sorry sir,
last thing I want to ask about ..
can u recommend me what Graphic card can I buy ..??
Mitarbeiter
6.052Aufrufe
Sure, you're welcome.
And, yes I can recommend some for your motherboard;
These are the officially tested for your motherboard, you can find more tested peripherals here; http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000007610.html Tested Peripherals for Intel® Desktop Board DH77KC. One thing you have to take into consideration is the following;
So, I recommend in this case checking with MAXON what graphics card will make the Cinema 4D work as expected.
Amy.
Mitarbeiter
6.052Aufrufe
Hope my recommendation helped you.
Let me know if there is something else we can help with.
Amy.
aahme20
Einsteiger
6.052Aufrufe
yes sir,
thank you very much ..
i'v already bought the Graphic card and hopefully it'll be alright ..
last question
how to know if i'm using the Nvidia card not intel one .. cuz when Maxon replied me they said make sure u r using the Intel card ..
with regards,
Mitarbeiter
6.052Aufrufe
Did you buy a Nvidia card?
Normally, you can't use Intel® graphics along with an external PCI Express graphics controller. Installing a PCI Express graphics controller disables Intel graphics. So, in this case you will need to get a clarification from MAXON on what they meant by "make sure are using the Intel card".
Amy.
Mitarbeiter
6.052Aufrufe
I hope that the previous helped you.
If you need further assistance let us know.
Amy.
Antworten
