I am experiencing an issue with my Intel Arc A750 GPU. After restarting my PC, I occasionally notice low GPU power usage and significantly reduced FPS while gaming. The problem persists until I restart the PC a couple more times, after which the GPU starts performing normally again.
Here are some key details:
- The issue happens after a restart, but sometimes the GPU performance is restored after restarting multiple times.
- I have updated to the latest Intel Arc GPU drivers.
- Power settings are set to “High Performance” in Windows.
- I have monitored the GPU temperature, and it seems to be within normal ranges.
- I have tried disabling Fast Startup in Windows, but the issue still occurs.
- My motherboard BIOS is up to date, and I have Resizable BAR enabled.
Could this be a driver-related problem, or might there be a conflict with power management settings? Any guidance or troubleshooting steps to resolve this issue would be greatly appreciated.
Thank you for your assistance!
Hello memento999,
- When did you purchase this unit?
- Was it working fine before?
- Did you change any settings before the issue started?
- Are you using an Intel brand Arc A750?
- Can you share the specification of your power supply?
- Can you also share the troubleshooting steps that you tried so far specially if you already tried different hardware components?
Michael L.
Hello memento999,
Michael L.
Hello memento999,
I am sending another follow up on the information that I requested.
Michael L.
