23838 Discussions
Iris Xe Underperforming
MrOrg11
Recently I started having issues with Intel Iris Xe performance. To be exact, I experience often stuttering while playing League of Legends, and FPS tends to drop from around 90 to below 10 several times a game. It also makes no difference whether I run the game on Very low, Medium or even High settings, the FPS changes insignificantly, yet the problems remain. Also worth noting that I was able to play at around 80FPS on high settings about a year ago, with no noticeable drops.
The system in question is an Acer Aspire 5, with the following specs:
  • i5-11357G 2.40GHz
  • 20GB RAM (16 in one slot, 4 in the other)
  • 512GB SSD
  • Intel Iris Xe
In addition, I couldn't identify any bottlenecks myself. CPU and RAM usage are usually below 50% when I play, and GPU usage hovers around 60% and peaks to 100% for a few seconds, several times a game. I ran the Intel Processor Diagnostic tool and everything passed. I also performed a clean Windows 10 Pro installation a few days ago, but the issue remained. Also, the latest driver is installed and power mode is set to Best performance.
Please help
Hugo_Intel
Hello MrOrg11
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing performance issues on league of legends when using Intel Graphics.
As a first approach to this issue, please completely uninstall the game from your system and reinstall it.
If the issue persists after reinstalling the game, please let us know the following information:
  • Is this the only game experiencing this issue?
  • Share a short video showing this issue.
  • Create a log file with the Intel® System Support Utility and attach it.
Hugo O.
MrOrg11
Unfortunately, the issue persisted after reinstalling the game. To answer your questions:
  • I experienced similar issues while playing Valorant and WoW;
  • I've been unable to capture the requested video, because of the severe frame drops that occur while recording. My overall in-game FPS dropped to 10-20 during recording, so I couldn't replicate the problem effectively. I used the Windows Game Bar recording setup. If you could recommend other recording software that wouldn't lower the FPS this severely, I would be glad to try it;
  • Find the log file attached below.
Hugo_Intel
Hello MrOrg11
Thank you for the information provided. Based on the log file that you shared with us, please let's try the following:
  1. Visit your system manufacturer's website and update your Bios to the latest version. The latest Bios seems to be 1.31.
  2. Do a clean installation of the latest driver provided by your manufacturer since this should be optimized for your system the version posted on their website is 30.0.101.1404. If the issue persists, proceed to step 3.
  3. Do a clean installation of our latest generic driver version 30.0.101.4125.
If the issue continues to happen after doing the above steps, please check your task manager when your system is idle and make sure that the processor is not been highly used or that there are no background applications consuming system resources.
Hugo O.
MrOrg11
Unfortunately, the recommended fixes only made matters worse.
Updating the BIOS first resulted in a BSOD, which led to some tweaking in the BIOS settings to resolve the issue. Afterwards, I tried out both drivers you recommended, and game performance degraded from earlier, with both of the drivers.
Now the game runs under 60FPS 80% of the time, making it almost unplayable. Random FPS drops to under 10 still occur. I monitored CPU, GPU and RAM usage while playing and the results are as follows:
  • CPU usage was constantly around 15-20%, with no noticeable spikes;
  • RAM usage was around 30%, also with no spikes;
  • GPU usage was above 85% most of the time, often spiking at 100%.
Testing was conducted on the lowest possible settings in League of Legends. No background applications were active and system was idle.
Hugo_Intel
Hello MrOrg11
I appreciate the troubleshooting you have performed. Before we further research this issue, please completely uninstall the game from your system and reinstall it to make sure there are no corrupted files.
Hugo O.
MrOrg11
Reinstalling the game didn't help. However, I noticed that the game runs smoothly when the power cord is unplugged, and all of the problems I described kick in as soon as I plug it in and start charging.
How can I resolve this?
Brine
Hey MrOrg11
I have same problems with same graphic drivers but i've found a solution to it (or maybe not), what i did was Factory reset my pc but without deleting files and other stuff. It actually worked at start, i didnt found any lags in my games and it was going well until after 2 months. It started to lag again but less then before.
So maybe try resetting your device but do it without losing your Files and other stuff.
n_scott_pearson
That sounds to me like there is something wrong in the laptop itself. This is the opposite of what would (I hesitate to say 'normally') be expected, That is, issues like this (if they are going to appear) should occur while on battery, not while on A/C power. I would thus suggest that you have a talk with Acer about this. It may be an issue in the laptop's configuration or it may be a physical issue in the laptop itself.
Hope this helps,
MrOrg11
Agreed, it seems it's not the Iris Xe underperforming, but rather something else causing the issue. If I manage to find a solution I will post it here, in case anyone else faces this issue in the future.
Thank you for your time
InputWrong32
I also have an Acer laptop with an extremely underperforming, graphics card the Intel Iris Xe. Have you found any solutions with contacting with the manufacturer (Acer)? Anything would help thank you.
Hugo_Intel
Hello MrOrg11
Thank you for letting us know. It is actually interesting that the issue happens when unplugging the A/C adapter, as @n_scott_pearson mentioned it should be the opposite. Please, also check that the power plan when connecting the charger is well configured for max performance.
Hugo O.
Newperson99
I have been having a similar issue with my own laptop recently and found your post while searching for possible solutions. My laptop is a Dell Inspiron 15 - i5 core, 12GB RAM, 521GB SSD, and Intel Iris Xe graphics. My gaming performance took a dive in the past week or so and games that once performed well became unplayable. Thankfully, I have found a solution that has currently fixed the problem, at least for my system.
Uninstalling Windows Update KB5022497, which was released on the same day you reported your sudden performance issues, seems to have solved the problem for me. My system reverted back to Windows Update KB5022404 and my gaming FPS is now back to normal. My GPU is also behaving normally again - it had been almost always maxed at 100% while running games under the newer update.
I don't know why this fixed the issue for me - the Windows update notes don't mention any changes affecting GPU performance that I can see - but if you you are still experiencing FPS problems you might want to check if you have update KB5022497 installed and attempt to roll it back if you have the option to do so.
I've seen a few other people with similar systems complain of performance issues this past week. One individual commented that they solved their problem by changing their laptop's battery mode from 'performance' to 'cool' - this could explain why your laptop performed better while unplugged. My best guess is that an update somehow caused problems with how laptop temperatures impact GPU throttling, at least while on 'plugged in' power settings. I am definitely no expert though, so this is all just speculation on my part. I just wanted to pass along this info.
Hope it helps.
Newperson99
Unfortunately, my FPS problems have gradually returned after I uninstalled the update described in my initial post. After several days, my gaming frame rate had significantly dropped again. I decided to reinstall update KB5022497 today and my FPS is back to normal, but it seems uninstalling and/or reinstalling Windows updates only temporarily solves the problem for me.
DeividA_Intel
Hello MrOrg11,
As you and n_scott_pearson, the behavior of this issue could be related to the laptop itself. I recommend checking also with the laptop manufacturer so they can run some tests on their unit to confirm if there is any malfunction with the laptop.
Thanks for your time and comprehension.
Please keep in mind that Intel will no longer monitor this thread.
Deivid A.
MK10
Yes, I also had the same issue, appearently its the graphics card.
Specs
Iris XE
i7 12th gen
24 gb ram(i upgraded)
500 gb ssd
When i first brought the computer in 2021 i downloaded valorant to play and i got solid 170 fps in high settings but randomly after a year right as the warranty expired my computer stopped functioning properly, the 170 fps dropped to 60 fps over the 2nd year. This is still going on, i just think its the unreliable integrated graphics card and there is no app or windows function impacting the graphics card. As of now my laptop even struggles to run roblox on the lowest settings, i get around 30-50 fps and the gpu clocks at 100% and cpu is at 40%. I have done multiple resets, bios updates, going back to windows 10 trobule shooting and pretty much everything but nothing seems to fix the issue making the graphics card at fault. Maybe next time don't buy integrated graphics card laptops with intel IRIS XE in it. My laptop was 1099, here is the link:https://www.amazon.com/HP-Pavilion-Touchscreen-i7-1165G7-HP-15-EG0073CL/dp/B09F2Y98MY?th=1  for this price just try getting a laptop with nvidia graphics cards or just settle with a pc. Overall i  do not recommend buying laptops with intel IRIS XE
madbrain1
If your Intel Iris Xe graphics are underperforming, try these quick fixes:
  1. Update Drivers: Ensure you have the latest drivers from Intel's website.
  2. Check Temperatures: Monitor temperatures with HWMonitor and clean your device’s vents.
  3. Optimize Power Settings: Use a high-performance power plan in Control Panel > Power Options.
  4. Close Background Apps: Use Task Manager to close unnecessary applications.
  5. Adjust Game Settings: Lower resolution and graphics settings in games.
  6. Update BIOS: Ensure BIOS settings are correct and check for updates.
  7. Scan for Malware: Use antivirus software to check for malware.
These steps should help improve performance.
MK10
I did everything on the list except for update bios. When i try to update bios it says i dont have any bios updates.  I have attached a video below on the screen that shows up
ANDREIonPS4
I have a HP Pavillion Laptop 15 eg aswell. I have the same problem, I don´t remember when it exactly started happenjng but it definetely started around February 2023. did your performance issues get fixed after doing all the fixes (except BIOS update of course)
MK10
No none of the issues got fixed, i searched up lot of tutorials. If you want performance and don't care about your cpu you can download parkcontrol ( this will damage your cpu).  i some what fixed the issue it definetly does perform better now .
1. i cleaned my vents and i removed the dust off the fan(there wasnt a lot of dust)
2. remove and apply new thermal pasts( my cpu temp was always at 90 but after replacing the thermal past now its at around 70 with gaming and 60 when working, these are not ideal temps and are way higher but i cant seem to fix the issue. i think this is the manufactures fault or intels fault, there is basically nothing we can do about it)
if you want to update your bios i dont think you will be able to update it because on the hp app where you update your bios there were was not an option to select HP Pavillion 15 eg, most likely meaning that they have stopped bios updates for this model. the latest bios update for hp pavilion 15 was in  2023 if you have that update you are basically uptodate and can do anything abt it
MK10
If you still have your warranty just use it now and dont think about waiting because it is going to get a lot worse later on.
