告知
22778 ディスカッション
Is it possible to adjust sharpness of the picture in the Intel HD Graphics Control Panel?
YYuri1
ビギナー
10,876件の閲覧回数
Hello!
Is it possible to adjust sharpness of the picture in the Intel HD Graphics Control Panel? Or I can only adjust the brightness and contrast?
Thanks!
0 件の賞賛
12 返答(返信)
従業員
8,683件の閲覧回数
Hello popovsqa ,
I would like to verify what is the "Sharpness" that you are referring to.
Is it something like this picture?
Also, what is the full model of your processor? What is the OS you are currently using? And what is the brand and model of your system (if pre-built or from an OEM)
Hope I can hear from you
Esteban C
YYuri1
ビギナー
8,683件の閲覧回数
Hi Esteban!
I'm sorry for waiting
Yes, like on the picture.
Operating System:Microsoft Windows 10 Pro(10.0.14393 Build 14393)
Processor :Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
System Model:NUC6i3SYB
Thanks!
従業員
8,683件の閲覧回数
Hello popovsqa,
I understand, thank you for the clarification and the information provided.
Let me further investigate if this options could be changed in some way, I was not able to find them in the control panel so I cannot promise they will be available, but indeed I will check.
Esteban C
従業員
8,683件の閲覧回数
Hello popovsqa ,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back and let us know:
What is the full model of your processor?
And what is the brand and model of your system? (if pre-built or from an OEM)I am looking forward to hearing from you.
Angie.
従業員
8,683件の閲覧回数
Hello popovsqa,
I would like to check if you still require support for this matter.
If you do, please provide me with the Intel SSU report, which gathers up important information so we can further assist you.
Here you can find instructions on how to get it done:
-Access: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
-Download the utility
-Scan your system with the utility
-Export the report (hit next and then save) and attach it to your answer with the advanced editor option (reply button and then check upper right corner)
Esteban C
従業員
8,683件の閲覧回数
Hello popovsqa,
I got the resolution for this matter.
The sharpness setting should be under video settings
In the main page of the control panel, please go to Video settings> Image Enhancement> Basic> Driver Custom Settings
You should see a slider there with sharpness setting.
Esteban C
YYuri1
ビギナー
8,683件の閲覧回数
Thanks for the answer. Unfortunately I can not find these settings. Could you show me the screenshots, please.
従業員
8,683件の閲覧回数
Sure, no problem, popovsqa
Here:
Esteban C
YYuri1
ビギナー
8,683件の閲覧回数
Unfortunately, it only adjusts the sharpness of video. I would like to adjust the sharpness of entire screen.
従業員
8,683件の閲覧回数
Hello popovsqa,
I understand, while being curious, I found this setting within my monitor's menu.
Have you checked yours? The settings that can be changed by Intel Control Panel are the ones mentioned already and the ones on 3D> Advanced.
Here a picture of the setting, and it does change the way you want.
Esteban C
YYuri1
ビギナー
8,683件の閲覧回数
Thank you, I know about the settings of the monitor sharpness.
従業員
8,683件の閲覧回数
Hello popovsqa,
Within the settings that you can change, the only related to sharpness is the one noted under the video section.
For the desktop or other apps, it would be the monitor setting.
Esteban C
返信
