I have an Asrock J5005-itx board with Windows 10 home and a samsung NU8000 UHD tv. If I leave the "HDMI UHD color" set to off on the TV, then I can display 4K @ 60Hz at 4:2:0 color, which has blurry edges on text. 4K @ 30Hz 4:4:4 works fine.
When I switch the samsung to have HDMI UHD color ON, then the signal is dropped and no image shows. With the UHD color on, the tv should support 4K @ 60Hz with 4:4:4 at 8-bit, but I cannot get this to work.
I would like to know if there are any graphics driver updates which might address this issue.
Scott
Hello sholt1,
Thank you for posting on the Intel ® communities.
I am currently attempting to replicate the situation you are experiencing to see if the issue is present, please allow me some time while this is done. I will be getting back to you as soon as possible, in the meantime, To better assist you with your request, please attach a DxDiag, follow the steps below to get the file:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
Hello sholt1,
Thank you for your response.
I have been reviewing the information and I have found that you are not currently using the latest graphics driver, this could be the cause for the current situation so I would recommend to update the graphics driver. You can download the latest one from your system manufacturer or you can use our generic drivers in the link below:
https://downloadcenter.intel.com/download/28515/Intel-Graphics-Driver-for-Windows-10?product=126788
Make sure to read all of the details and description of the driver before proceeding with the installation.
In case the issue persists with the latest drivers, this could also happen due to low quality HDMI incapable of driving sufficient bandwidth, I would suggest using new High-Speed HDMI cables. Also, you need to make sure if your panel (display) is an 8-bit display, if the display is 10-bit then it will not output the 4K @ 60 Hz 4:4:4.
David V
Hello sholt1,
Were you able to check my previous post?
Let me know if you need more assistance.
David V
Topic Options
