22936 Discussions
Is there a way to Deploy the Intel Drivers and Support Assistant with having the Auto-check Scan Frequency set to never?
BDill3
AndrewG_Intel
Hello BDill3,
Could you please help us to clarify what exactly you are trying to achieve with Intel® DSA and provide more details regarding what you mean by "Deploy Intel® Driver & Support Assistant with having the Auto-check Scan Frequency set to never"?
Do you mean to perform or create a custom/silent/distributable installation of Intel® DSA with the Auto-check Scan Frequency set to never as a default option?
Andrew G.
A Contingent Worker at Intel
BDill3
Yes this is what I'm looking for....... Perform or create a custom/silent/distributable installation of Intel® DSA with the Auto-check Scan Frequency set to never as a default option?
AndrewG_Intel
Hello BDill3,
Thank you for your response.
After checking your inquiry regarding the possibility for custom/silent/distributable installation of Intel® DSA, I would like to confirm that at this moment we do not have options to deploy Intel® DSA this way.
The only option to set Auto-check Scan Frequency to Never is to manually set it in Intel® DSA Settings and this needs to be done for every instance of Intel® DSA.
I will share the feedback with the product team so they may consider it for future releases.
Please let us know if you have additional inquiries.
Andrew G.
