Good afternoon, I am trying to install this graphics driver update but whenever I try to install the installation fails every time. I've tried manually installing, installing through Intel Arc Control and also Intel Driver & Support. I was hoping someone has a fix for this issue. Thank you and have a wonderful day. It's a brand new PC if that helps, if anyone needs any more information feel free to ask.
Hello Quudi,
Thank you for posting on the Intel®️ communities. You seem to be having trouble installing driver 31.0.101.4952; I will be pleased to assist you.
To better understand the issue, please answer the following questions:
- Is there any error message when trying to install the driver? If so take a screenshot of it.
- To know your system environment run the Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Hello Quudi,
Were you able to run the Intel® SSU check your system information?
Andres P.
Hello Quudi,
Andres P.
Anche io ho questo problema, ogni volta che provo ad installarlo appare questa schermata e si blocca tutto. Spero di riuscire a risolvere al più presto.
