22866 Discussions
Issues with graphic interface with Panasonic TH50PX25
Krimson
INTEL HD GRAPHIC 630
WIN 10 PRO
Connection: HDMI
computer: DELL 5050 DFF (no modifications)
Monitor: Panasonic TV TH-50PX25
driver installed TH-50PX25U
ISSUE: When I connect to the TV using the HDMI for better resolution the viewing area on the TV larger than the actual TV screen by about 2", Therefore I cannot see any menu on the right, left, or bottom because they are off-screen from the actual physical viewing ares.
NOTE: this was an upgrade from a 32 bit to 64 bit system and from Win 7 pro to Win 10 pro.  On the Win 7 system with a GEFORCE 710 graphic card, it worked fine but was not as clear.
Troubshooting: Tried changing the resolution way down and started to see the edges of icons on the left side of the screen. Resolution was poor.
Installed the 32 bit graphic card, and it didn't do any better
The system installed a driver for TH-50PX25U and will not allow me to change the driver (or I don't know how)
I was thinking of using the driver for a TH-40PX25U since it is a smaller screen size, but not sure if that would work, nor could I find one, or even how to install it in Win 10 which I have never liked... Yeah, I am al Old Tech and outdated... LOL
Any help would be greatly appreciated...
<email removed>
MUC
Honored Contributor I
Panasonic TH-50PX25 TV - Operating Instructions
You may need to adjust the picture settings on the TV. Please refer to pages 56-58
Krimson
Thank you, it appears that the aspect adjustment does not work in HDMI but it did work with other settings such as video input or PC input... just not THE HDMI INPUT SETTING...
Krimson
DSC00024[1].JPGpicture of screen all menus off screenpicture of screen all menus off screen
I expanded-stretched the menu section on the left side so I could try to see the menu as you can see but I still can't find the power shutoff icon. you can see on the left side that I made the icons maximum size and they are barely showing. Do I need to get a used 3rd party 64 bit  graphic card to fix this? thank you
MUC
Your screenshot of the Intel HD Graphics Control Panel shows that the resolution is set to 1920 × 1080.
The native resolution of this TV's panel is 1366 × 768 according to the manual. Please try what happens if you lower the computer's resolution to this setting.
