22922 Discussions
Keyboard shortcuts to screen rotation, only available for main screen.
JanusDC
I am using three monitors, and I would like to link the keyboard shortcuts to rotate the monitor to one of them which is not the main screen. The Intel app only allows to use the shortcuts in the main display. Is there anything I could do?
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
JanusDC
I am asking for a new feature in the program. I do not see how my particular system information would be of any help. But here it goes.
Alberto_Sykes
JanusDC, Thank you for posting in the Intel® Communities Support.
Just to let you know, we will double-check on this scenario in order to try to provide the most accurate response to your inquiry. As soon as I get any updates, I will post all the details on this thread.
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello JanusDC, I just received an update on this matter.
After trying to replicate this scenario in our Intel® Lab, we can confirm that the keyboard shortcuts to rotate the monitor, by design, will only work with the main screen that is connected to the computer.
Albert R.
JanusDC
