- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I am unable to select the 2560x1080 resolution for my ultrawide monitor. I have downloaded the latest drivers from LG for my monitor and also downloaded the latest Graphics driver, 31.0.101.2125. When I go to Display Settings > Advanced Display > Display adapter properties > List All Modes, the option is not available. I am using a HDMI to HDMI connection without any adapters.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
According to the diagnostic report, the device is a Dell Inspiron 15 3511. For this laptop, Dell states:
Ultimately, the information provided by the Original Equipment Manufacturer (OEM) is always decisive for the technical capabilities of a computer. In this case Dell. The signal that can be provided on an HDMI port depends not only on the graphics integrated in the processor, but also on the signal path to the port. Dell has apparently decided on a maximum of 1920 x 1080 here. You may need to contact Dell Support.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello mcappleman,
Please provide the following information in order for us to further isolate the issue and provide you with a solution:
- When did the issue start, and have you been able to select the 2560x1080 resolution for your ultrawide monitor before?
- Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article How to get the Intel® System Support Utility Logs on Windows*. Please send us or share with us the generated SSU.txt file.
Thank you, and have a great day ahead!
Carmona A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello mcappleman,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Mcappleman,
Thank you so much for the response.
All the information that was provided by @MUC was correct; in regards to that, we advised that you contact your OEM, which is Dell technical support.
Carmona A.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
