23851 Discussions
Latest driver supporting 3rd and 4th Generation Intel® Core™ Processors with Intel® HD/Iris™ Graphics for Microsoft* Windows 7, 8, & 8.1 version 3496
ROBERT_U_Intel
Windows* 7/8/8.1 GFX Driver Version 3496
Greetings everyone!
We have officially launched our latest driver supporting 3rd and 4th Generation Intel® Core™ Processors with Intel® HD/Iris™ Graphics for Microsoft* Windows 7, 8, & 8.1. The version is 3496 and is available at the following locations.
32-bit: Driver Download http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23713 here - Release notes http://downloadmirror.intel.com/23713/eng/ReleaseNotes_GFX_3496_32.pdf here
64-bit: Driver Download http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 here - Release notes http://downloadmirror.intel.com/23714/eng/ReleaseNotes_GFX_3496_64.pdf here
Also; http://www.intel.com/support/graphics/sb/CS-033838.htm Windows* 8/8.1 Graphics FAQ.
Please provide only constructive feedback here. Harassing comments, needless insults and personal attacks are not permitted, and will be promptly deleted.
If there are issues that carried over from previous drivers that you are still experiencing, feel free to announce them again here.
KYell
Even this Intel HD Graphics 4000 showed useless to me. I tried each and every update of drivers, which you people provided. But from day 1, when I purchased this PC with DH61H0 motherboard, with Intel i3 3210 processor, with windows 7 64bit graphic card drivers are not working. (This problem continues with Windows XP, Windows8, Windows8.1)
My system show weird bars all over the screen, when the system restarts after install HD Graphics drivers. These bars appear after the "Windows7 is Starting Now" screen. Here is how it looks after installing it.
This screen works normally only after uninstalling graphic drivers in "Safe mode"
Of couse, my PC works normally but, it says "The Videocard installed on this computer doesn't meet the minimum system requirements" or "Your hardware acceleration is either disabled or not working properly" whenever I am trying to use programs like windows movie maker, etc.
I tried even updating my BIOS, but even it proved useless.
Hope, so you people might provide some solution or simply I have put this waste motherboard into dustbin and purchase some other company's motherboard.
I am sorry, this might be hurting you... But, I got vexed with your Intel HD Graphic drivers. I have used many PC intel boards earlier since nearly 15 years or s0 (Right from Pentium Pro) but never faced such problem.
Even if you cant provide solution, then just simply say me to purchase some other motherboard (from some X manufacturer) I will do that.
Thanking You,
Kalyan
ROBERT_U_Intel
@ Kalyan, We are currently looking into the issue you are seeing.
Robert
XFiTr
Hi Robert,
Probook 4540s with Intel HD 4000 and amd 7650M
Intel i5-3230M CPU 2.60hz ram 4gb x64
win 8.1 Pro
3496 tested.
No code 43 on switchable mode Off(Bios) but Control Panel don't start.
Code 43 on switchable mode On. Control Panel and CCC don't start.
I need to know if somebody is working on these kind of issues. Notebooks win 8.1 hd4000 and
discrete gpu like amd 7650M?
Anyhow... on switchable mode OFF on Bios... control panel dont run
ROBERT_U_Intel
@ Bokefas, Do you also have the latest drivers from AMD for the 7650M?
Robert
XFiTr
Hi Robert,
thankyou for your answer
Yes, i also have the lastest amd 7650M drivers from HP and AMD generic drivers.
All tested in Bios Switchable mode ON... HD 4000 code 43 and and AMD working properly.
Anyhow Intel Control Panel and CCC never start.
Right now, Switchable mode OFF with an Intel drivers v.3496. Seems that it's working properly on
control panel but Intel Software don't start.
ROBERT_U_Intel
@Bokefas, Is this the AMD driver you are testing:
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
Also, when installing the graphics drivers did you install the Intel HD Graphics driver first, reboot, then install the AMD graphic driver?
Robert
XFiTr
Hi Robert,
Yes, this is the amd driver tested next to 3496 intel driver.
First installed the intel driver ..reboot .. and then amd driver..
During AMD installation, black screen and restart by pressing the pc button.
Amd installation completed succesfully but both cards code 43 on control panel.
Just a particular thing... only with "amd_catalyst_14.1_mobility_betav1.6"
Catalist Control Center runs with only few functions like presets and hydravision.
DJ1
How long do you wait between getting the black screen and pressing the pc button? Just checking. This also likely wouldn't be an intel driver issue if your saying it installs and you restart the computer fine with proper display and then this issue arrises after the amd driver. I assume that your already posting all of this in the AMD forums as well, as that driver seems the cause of the problem. Could even be a faulty card it does happen.
RThon
Any progress with solving the Dolby Digital+ issue with the Netflix Metro app in Windows 8.1 ?
JSkau
New Contributor II
I don't think that is really related to the GPU driver. Make sure you have IME (Intel Management Engine) driver installed: Download Center (And Legacy usb disabled in bios). From a previous post I found that your unit is NUC DC3217IYE - if this is correct, the above driver should be correct.
This driver is not available yet for most 4th gen / Bay Trail platforms - so no DD+ or DTS-HD under windows, unless they've come up with another approach to Protected Audio Path - and intend to fix it (as if this is the case, its currently broken)... or you find some way of bypassing PAP.
Intel has provided feedback that they've "told development team to do something" , but 3-4 months and still no driver.
RThon
You are right, I have an NUC DC3217IYE running Windows 8.1 Pro.
I have legacy usb already disabled in bios as well as legacy boot.
I also have the IME (Intel Management Engine) driver installed.
DTS-HD and DD+ work fine in Windows, with the Dolby test movie for example and DTS-HD in XBMC.
But DD+ still won't work in the Netflix Metro app.
There are currently 2 ways around this issue:
1. Install the Microsoft display audio driver, then DD+ works but I lose DTS-HD.
2. Start a Netflix series like House of Cards which has DD+, go to the audio device settings and try to set it to stereo.
This will produce an error and then DD+ will work until you stop playback.
At some point before in Windows 8 it has worked, but stopped working after the Windows 8.1 update.
This all point heavily towards the display audio driver in my opinion.
JSkau
New Contributor II
DD+ doesn't require Protected Audio Path in principle, thus playback with other capable applications might have better luck. PAP is a requirement of the Netflix metro app.
JSkau
New Contributor II
Add: PAP might be broken with Intel Management Engine (or other way if intel devised such) under win8.1 . This /could/ explain the long lack of driver for Bay Trail, as those came after the fact.
RVand51
Big thanks to the Intel team for their great work making and releasing this driver so quickly! Your efforts and dedication to making gaming possible on intel have not gone unnoticed and is greatly appreciated.
I have recently installed the new driver and wanted to give my feedback on it progress. I had been playing Titanfall on the Beta2 driver. Since installing the current driver I have seen drastic improvements with it gameplay. Though I still am experiencing lag at times, (Mostly outside of buildings on maps with heavy fog or mass amounts of titan action.) I have been able to run the game at High-Medium settings smoothly with minimal lag. (Very High settings worked well indoors only.)
If anyone can, please post your fps you are getting on the different settings. I am unsure how to monitor that unfortunately.
HP Envy 17.3" 1080P i7-4700mq
2.4GHZ-3.4GHZ turbo boost
16GB ram
intel HD 4600
XFiTr
@Dre:
Thanks for your interest.
Before you press the button, let it go a few minutes, probably continuing the installation of the driver while the screen is black.
when I restart the computer, amd program window and amd website appears istallation completed succesfully,
and reboot again.
After reboot.. both cards code 43.
this issue has been treated only for probook 4540s and 4740s in forums hp, hp unanswered users. Do not think it's a manufacturing defect.
One thing I do not understand ...
Why does not any intel driver works in switchable mode OFF from bios (disable discrete gpu amd 7650m graphics). Seems that its working properly but dxdiag shows only microsoft display and Intel Control Panel never start.
@Robert_U: Tested installing first Intel driver and then amd driver. You can see what I have written to dre.
Thanks for your interest and help
BJ1
Just installed 10.18.10.346 on intel 4400 and no matter what I do I can't get the dam* tray icon to stay disabled. It always starts back up after reboot/restarting.
Ooops forgot to mention that this is Win8.1 x64
BJ1
Also with this driver when I establish a WiDi connection the WiDi Audio is not enabled. I have to manually go in and set it as the default audio device otherwise I'm left with my laptop speakers
NHeim
Has anyone responded to the tray icon issue? I'm having the same thing. Fresh installed of Win8.1 64bit. Just curious if there was a fix. I have a Dell Latitude e5540 that contains an nVidia card as well as the Intel HD 4400. No matter how many times you uncheck it it only goes away for that logged in session. I'm a computer tech and this is baffling me.
mSolo5
Anyone having monitor standby issues, when windows signals the display to go off
the screen goes black, but backlighting stays on, the driver is not properly putting the monitor in power save mode.
my monitor would sleep fine, with AMD/ATI card... but not with intel graphics i7-4771
monitor(dell U2410) is connected via DVI
I need solution, I cant have my backlight on all the time...
training myself to turn off the display manually is only short term
NNiko6
Hello Robert.
It's been a month since my last post regarding driver issues here /message/225628# 225628 https://communities.intel.com/message/225628# 225628
and I didn't get an answer.
I'll post here again my issues regarding the new driver 3496 and my older post.
No 1 about HEVC support has been answered in another Intel thread
No 2 the quality score of Cinebench R15 OpenGL test is the same as 3412, a little lower than AMD and Nvidia
No 3 the VC1_VLD2010 is still limited in 1080p decoding
No 4 this seem to be fixed because after the upgrade of the driver the VPP functions were all set to "Application settings" and all the other settings were set to "Off".
I don't know if a clean install of the driver (not upgrade) would have same behavior or the upgrade kept my old settings
No 5 is the MadShaders v0.3.0 OpenGL benchmark/test and has some fixes to Space Racing Lite, Creepy Mountains and # 9110.0 but there are still unfixed shader programs which are looking worst than previous driver, after the above fixes!
So the problems with MadShaders are:
1) Crash in # 6254.0 test
2) Corruption in:
a) Distance Estimated DoF
b) Britney's Spaceship
c) Fractal Cartoon
d) Dolphin
No 6 I have no new info about Intel's GPA crash and zero media metrics with new driver and GPA 2014 R2 using Windows 8.1
No 7 Pentium G3420 is still reported as no Intel Clear Video HD capable processor
No 8 No InTru 3D capable
No 9 Video decoding capabilities are still no clear in the release notes
No 10 I got an answer from Doom9 forum
