22644 Discussions
Lenovo M83 video issue
OOsva
Hi everyone,
I'm using Lenovo M83 tiny PC with an Intel 4600 graphic card. I have connected 2 different screens to this PC by using HDMI and DP outputs.
I'm using this PC to run 2 FullHD videos on these screens. At the bottom of first video there is a crawling text which goes from right to left, and it doesn't go smooth. It 'stutters'. When just one screen is used, crawl goes smooth.
I've noticed that CPU goes high when both videos are running. Btw, I'm using Scala Player (Digital Signage solution) to run these videos.
Graphic driver version: 10.18.14.4264
Is there something which can be done to tweak the CPU, GPU, memory, to get better graphic performance from this PC?
Thanks for help!
Regards!
Hello toto_riina,
I would suggest the following:
Since you have a Lenovo system and they could have incorporated customization on your system uninstall the graphics driver and then reinstall it, please see http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html?wapkw=intel+display+audio Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver, once you uninstall this driver restart your system and then manually install the latest driver that Intel has released:
Please see http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 & Windows 8* or Windows 8.1* and http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*
Download the graphics driver here: https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496
Caution: Intel supplies generic versions of its graphics drivers for general purposes, but the computer manufacturer can change the features, incorporate customizations, or make other changes to the graphics driver software or software packaging. To avoid any potential installation incompatibilities, Intel recommends that you first check with your computer manufacturer and use the driver software it provides.
Best wishes,
Ivan
OOsva
I've made it working ok. I've just adjusted Windows for best performance for visual effects.
Control Panel – System – Advanced system settings – Advanced – Visual effects – Adjust for best performance.
And now text crawl works fine.
