23281 Discussions
Looking for similar utility in BIOS. ASUS--> NZXT
SmoothBrain
https://community.intel.com/t5/Processors/i9-13900K-very-frequent-crashes-Windows-11-with-apps-games-and/td-p/1527297
In reference to the above post.  The solution for solving this problem had the user adjust their SVID Behavior setting in their BIOS to INTEL Fail Safe.
Since I use an NZXT motherboard, i am unsure if i have a similar setting or way to configure in my own BIOS. I did not see such options when i glanced through it.
I believe i am suffering from a similar issue.
RamyerM_Intel
Hello SmoothBrain,
Upon reading the thread, I noticed that this is about frequent BSOD issue. Although you might have a similar issue, it is best if we can gather more information since you have different systems and might require different troubleshooting. As such, kindly please share the following details:
  1. When did the BSOD occurs?
  2. What are the error message that you have received?
  3. It mentions in the thread that the user did not overclock, is the same with your case as well?
  4. Were you also able to run the Intel Processor Diagnostic Tool in your system?
  5. Since there are several apps mention in the previous post, please also let us know what software/games are encountering this issue.
  6. Kindly also please attach the SSU logs of your system in this post. You may download and run the Intel System Support Utility at this link: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
  7. To avoid repeating the same steps that you have done, please let us know of any troubleshooting you have already taken
Ramyer M.
RamyerM_Intel
Hello SmoothBrain,
I am just following up regarding the information we have asked. Please reply to this post so we can further understand what is causing the frequent crashes in your system.
Ramyer M.
RamyerM_Intel
Hi  SmoothBrain,
As we have not heard a response in the past few days, we will proceed in closing this thread. If you need further assistance about the crashes in your CPU , please submit a new inquiry as this thread will no longer be monitored.
Ramyer M.
