22679 Discussions
Lots of screen tearing in all games.
PBisw5
3 395 Visites
I played Counter Strike 1.6 and CS GO just fine with low settings. I am getting horrible screen tearing from the last month. I didn't change any video or game or driver settings. I have a 60 Hz monitor. My cpu is i5 4440 and gpu is Inter® HD Graphics 4600. My driver version is 10.18.10.3540 and I have reinstalled it many times but still getting the tearing. "It didn't happen before. I am sure about that". Even during Windows startup (Windows 7), when the fire flies rotate I get a bit screen tearing. Please help 😞
0 Compliments
10 Réponses
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
There are newer graphics drivers for Intel® HD Graphics 4600 for 4th Generation Intel® Core™ Processors. The latest version is 4332.
It is possible to download the latest drivers from the link below.
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors Drivers & Software
I suggest you to double check if your motherboard (PC) manufacturer released new drivers.
Mike C
0 Compliments
PBisw5
2 466 Visites
Hi mikec_intel,
I updated it to the newer driver version 10.18.14.4332, but the screen tearing persists. Is my Intel hd graphics wearing out?(I don't see any fps drops) Should I resinstall Windows 7 on my pc? Does that help?
0 Compliments
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
Verify if your PC has the latest Chipset and Management Engine drivers from the board manufacturer website.
Intel already tested the game CS GO with the HD graphics 4600. Intel suggested the settings below.
https://gameplay.intel.com/GamesSettings/6896/75038/Intel%C2%AE%20Core%E2%84%A2%20i5-4440%20Processor%20(6M%20Cache,%20up%20to%203.30%20GHz https://gameplay.intel.com/GamesSettings/6896/75038/Intel%C2%AE%20Core%E2%84%A2%20i5-4440%20Processor%20(6M%20Cache,%20up%20to%203.30%20GHz)
Mike C
0 Compliments
PBisw5
2 466 Visites
Hi mikec_intel,
Thank you. I will try that settings. Still asking , does an intel gpu fail or wear out or is it robust like that of the cpu (i.e. if the cpu is upto the mark so is the iGPU) ??
0 Compliments
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
The graphics are embedded in the processor and they provide with the same quality of the cpu. Now, the processor itself has a microchip inside, it will slow down the processor speed including the graphics if temperature if high while running heavy workloads.
Mike C
0 Compliments
PBisw5
2 466 Visites
Hi Mikec_intel,
Thank You for your reply. My temps are 42°C while gaming and during stress tests they are 53°C and during idle they are 30°C. Si I hope thats normal.
X0du$
0 Compliments
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
Your processor is working under the expect parameters. Thank you for your feedback.
Mike C
0 Compliments
PBisw5
2 466 Visites
Hi mikec_intel,
Can you please help me in downloading the older version of Intel Processor Diagnostic Tool 64bit Version 2.20.0.0.W.MP-1. I will be greatly obliged if you provide me the link directly for downloading it.
Thanking you,
X0du$.
0 Compliments
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
Intel already released a new version of the tool and remove the old version from the database. I regret the inconvenience.
Intel® Processor Diagnostic Tool v3.0.0.25
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Mike C
0 Compliments
Anonymous
Non applicable
2 466 Visites
Hi X0du$,
The latest graphics driver version is 4414 available in the link below:
Intel® Graphics Driver
https://downloadcenter.intel.com/download/25978/Intel-Graphics-Driver-for-Windows-7-8-1-15-36-?product=81496
Mike C
0 Compliments
Répondre
