I have a Thinkpad X1 Carbon Gen 13 laptop with Core Ultra 268V and Arc 140V graphics. I am trying to connect to Samsung Neo G9 57 (7680x2160) Display through Amazon Basics Thunderbolt4/USB4 Pro Docking (HDMI 2.1 output supports up to 8K30Hz) like so:
Laptop -> Thunderbolt 4 Dock -> Neo G9 57 Display
On ArchLinux with Kernel 6.17.6, I am able to to output with the native resolution 7680x2160 at 59.99Hz. Please see my screenshot and EDID decode as attached.
However, on Windows 11, I am unable to select the native resolution 7680x2160, only up to 5120x1440. Please see my screenshot below and EDID export from CRU as attached. I am also using the latest available Intel Graphics Driver 32.0.101.7029.
Hi YUKW,
- May I know if you are using the same laptop with Windows OS and Linux?
- Have you tried to connect the external monitor directly to laptop?
- Have you tried using the OEM driver for testing?
- Have you used Display Driver Uninstaller (DDU) to completely remove all residual drivers and installed a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Patrick V.
I have previously tried connecting the external monitor directly to laptop's HDMI port, but the max resolutions remain the same. That's why I am trying to use the dock.
I have also just used DDU to uninstall display drivers and revert back to Lenovo Thinkpad's driver 32.0.101.6326, but the results are the same.
Hi YUKW,
To help troubleshoot this further, could you please confirm if you've tried the following steps:
- Update dock firmware - Check if your dock firmware is current by visiting the manufacturer's support website for any available updates.
- Update system BIOS - Ensure your system BIOS is running the latest version from your computer manufacturer.
If you've already completed both updates and the issue persists, this may indicate a system compatibility issue with your specific hardware configuration.
Since this is an OEM product, if the problem continues after trying these troubleshooting steps, I'd recommend contacting your system manufacturer (OEM) directly for further assistance. They'll have specialized knowledge of your hardware setup and can provide targeted support for any compatibility concerns.
Patrick V.
Samsung Odyssey Neo G9 (G95NC) – user manual attached
7680 x 2160 @ 240 Hz (pixel clock: 4233.6 MHz)
7680 x 2160 @ 120 Hz (pixel clock: 2224.75 MHz)
Lenovo ThinkPad X1 Carbon Gen 13
1 x HDMI TMDS (aka HDMI 2.0)
2 x Thunderbolt 4 (with DisplayPort Alternate Mode HBR3 w/ DSC)
For optimal operation, this monitor requires a signal with Display Stream Compression (DSC). While the included EDID indicates DSC capability, the docking station's "8K@30 Hz" HDMI specification could mean that it may not support DSC. The laptop's HDMI port doesn't either.
Just connect one of your laptop's Thunderbolt 4 ports to your monitor's DisplayPort input.
Please use one of the following cables. The connection will then be operated with the DisplayPort 1.4a HBR3 protocol w/ DSC:
- Zeskit MAYA 8K Bi-Directional USB-C to DisplayPort 1.4 Cable
- Club 3D USB Type C Cable to DP 1.4 (CAC-1557)
- Cable Matters USB-C to DisplayPort Cable - 8K Ready (201036)
- Cable Matters Premium Braided USB C to DisplayPort 1.4 Cable (201336)
The total available bandwidth will probably not be sufficient for 240 Hz, but 120 Hz should not be a problem:
7680 x 2160 @ 120 Hz >>> 2224.75 MHz = 206 % HBR3 … with DSC = OK
If you're keen to experiment, you can also test whether Lenovo can keep its word on its technical specifications:
2 x USB-C (Thunderbolt 4 / USB4 40Gbps), with USB PD 3.0 and DisplayPort 2.1
If Lenovo fully utilizes the processor's capabilities with a corresponding retimer on the printed circuit board, then UHBR link rates according to DisplayPort 2.1 are also available in DisplayPort Alternate Mode according to the processor's specifications (page 152):
DPx4 means that 4 lanes are used for the video signal. This would lead to:
UHBR10 (4 x 10 Gbps): 7680 x 2160 @ 240 Hz >>> 4233.6 MHz = 266% UHBR10 ... with DSC = OK
UHBR20 is not supported by the monitor.
If you want to try this, set the refresh rate to 240 Hz in the monitor's On Screen Display (OSD).
Game → Refresh Rate → 240 Hz
For details, please refer to the user manual.
Use this cable then:
Club 3D CAC-1563 USB-C to DisplayPort 2.1 DP54 Bi-Directional Cable 2 m
Hi MUC,
Thank you for providing further suggestions regarding the issue encountered by YUKW. I really appreciate it and hopefully, it may help other community members experiencing similar behavior.
Hi YUKW,
I just wanted to follow up to see if you had a chance to review the information I posted. Your feedback at your earliest convenience would be greatly appreciated. Thank you.
Patrick V.
