22713 Discussions
Max refresh rate and resolution that HD Graphics 630 support ?
sud747
Débutant
36 133 Visites
Following is my system configuration :
intel i3 7100 Kaby Lake
Gigabyte H110M-H-CF with HDMI 1.4
16+8GB Corsair DDR4 RAM 2400MHz
I am about to upgrade my monitor and looking to get at least 32 inches, 2K resolution, 1ms response time with higher refresh rate (from 144Hz - 200Hz). I am curious to know if my existing processor and motherboard can handle it or not ? should add graphics card with display port to support my upgrade ? if yes then plz suggest some good options that is compatible with my existing hardware. I am not a hardcore gamer or content creator, just a casual user.
0 Compliments
DeividA_Intel
Employé
36 105 Visites
Hello sud747,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® HD Graphics 630.
In this case, Intel recommends you use a dedicated video card since this will improve the performance and will allow the processor to improve the performance. I recommend you check with Gigabyte to check the supported video cards by their system.
If you want to use the integrated graphics (Intel® HD Graphics 630), bear in mind that these are the supported resolution by the Intel® HD Graphics 630:
1. Max Resolution (HDMI)‡ 4096x2304@24Hz
2. Max Resolution (DP)‡ 4096x2304@60Hz
3. Max Resolution (eDP - Integrated Flat Panel)‡ 4096x2304@60Hz
Also bear in mind that HDMI 1.4: Supports up to 4K (4,096 by 2,160) at 24Hz, 4K (3,840 by 2,160) at 30Hz, or 1080p at 120Hz. HDMI 2.0: Supports up to 4K at 60Hz, and later versions (HDMI 2.0a and 2.0b) include support for HDR.
Please let me know if you have any further questions.
Deivid A.
Voir la solution dans l'envoi d'origine
0 Compliments
5 Réponses
DeividA_Intel
Employé
36 106 Visites
Hello sud747,
Deivid A.
0 Compliments
dimonissimo
Débutant
33 562 Visites
And what is the highest refresh rate for 2K (QHD) resolution? I have only 60hz on it
0 Compliments
sud747
Débutant
36 097 Visites
Thanks a lot for that quick reply, will go with dedicated budget graphic card that can support my gaming monitor.
0 Compliments
DeividA_Intel
Employé
36 067 Visites
Hello sud747,
Thanks for your response. I am glad to know that the information provided was useful for you. I will proceed to close this thread, however, you can open a new one in case you need further assistance or if you face an issue with any of our products.
Deivid A.
0 Compliments
sud747
Débutant
35 986 Visites
Could you please let me know what resolution and max refresh rate this i3 7100 can support via displayport like you explained for hdmi1.4 ? I am thinking of buying one of these https://www.amazon.in/gp/product/B08FCHQXSQ/ref=ox_sc_act_title_1?smid=A2PAIMNRE7S3TW&th=1 instead of dedicated graphics card will this be able to run 1440p @higher refresh rate (from 120-165Hz) ?
0 Compliments
Répondre
