22940 Discussions
Monitor does not have the resolution/refresh rate that I want
LucasKT
I want to use lower resolution because I play competitive games in 4:3. The problem is that I can only use 120hz with 1920x1080 or 1024x768 and nothing in between. All the resolutions that interest me are out of reach, as well as when I try to add a new one it does not work. I have Intel integrated graphics and a RTX 3050ti, so all my settings in this regard are only in Intel Graphics Center or Windows, and both options seem to not work for me right now.
I have all the drivers updated for the graphics card, and for Intel UHD graphics.
MUC
Honored Contributor I
Could you specify your device? Is this a laptop? The exact make and model would be helpful.
Could you please also run the Intel System Support Utility? Please select
and safe the scanned information to a local file and attach it here. No personal information is collected. It's just for support purposes.
LucasKT
Hi, It's a laptop.
The following model.
Gigabyte G5 MD-51DE123SD.
Attached is the system info file.
I also already tested the monitor on other laptop and it works just fine.
MUC
According the file you attached the monitor is driven by the Intel UHD Graphics (11th Core i5-11400H) via HDMI 2.0 [16].
The Nvidia GeForce RTX 3050 Ti Laptop GPU seems to drive the Laptop Display which is currently switched off.
  • Have you tried a CLEAN reinstallation of the Intel graphics driver?
  • Could you also run the System Support Utility (SSU) on the other laptop?
  • What is the resolution/refresh rate you'd like to set that works with the other laptop?
