23488 Discussions
Monitor does not sleep with latest Intel GFX drivers
Hi, so I installed the latest drivers for my HD2500 GFX, I noticed they fixed the issues with the CYBCr resting itself but now my monitor does not go to sleep, it just goes to a black screen and stays powered on, anyone else have this problem, any fix available apart from using an older driver that have the CYBCr issue.
Cheers.
Kevin_M_Intel
Hello raven77,
Can you please post the Dxdiag report so we can check some more information about your system?
You can do the following to get the information:
Start > Run > type in dxdiag then click OK.
When it finishes, click on the Save all information button at the bottom.
Open the text file you create.
In the notepad toolbar,
Edit > Select All
Edit > Copy
Hi, info you requested is below, I have reverted back to the previous driver to get monitor sleep state back. cheers.
System Information
Time of this report: 6/12/2013, 14:13:53
Machine name: JOE
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: 3603
Processor: Intel(R) Pentium(R) CPU G2020 @ 2.90GHz (2 CPUs), ~2.9GHz
Memory: 8192MB RAM
Available OS Memory: 7132MB RAM
Page File: 1888MB used, 6242MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: The file cmudaxp.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0152&SUBSYS_844D1043&REV_09
Display Memory: 1792 MB
Dedicated Memory: 992 MB
Shared Memory: 800 MB
Current Mode: 1920 x 1080 (32 bit) (73Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: S275HL
Monitor Id: ACR0313
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3071 (English)
Driver Version: 9.18.10.3071
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread group
Driver Attributes: Final Retail
Driver Date/Size: 3/19/2013 21:31:48, 8647680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4212-11CF-0C78-47A4B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0152
SubSys ID: 0x844D1043
Revision ID: 0x0009
Driver Strong Name: oem27.inf:5f63e534c477ad23:iIVBD0:9.18.10.3071:pci\ven_8086&dev_0152
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend...
Kevin_M_Intel
Marian
Hi Kevin,
I have experienced the same issue. Using Win7 on Intel NUC (GPU HD4000), graphic driver GFX_Win7_Win8_64_9.18.10.3165 - monitor does not go to standby, only goes to black colour. I had to uninstall newest drivers reboot and then install previous version. I can provide later today more details if needed.
Marian
You're wrong mate, the HD2500 is supported in windows 8, you can download the drivers for it from the intel download centre.
Yeah they messed up monitor sleep states trying to correct the ycbcr issue, it used to reset itself to off whenever monitor signal was lost like when it goes to sleep, they fixed it with the latest driver by not putting the monitor to sleep lol.
Marian
Hi Kevin,
I have installed your driver Win64_15319.exe (binary same with GFX_Win7_Win8_64_9.18.10.3165.exe) and issue with black screen colour instead of standby has appeared again. Please find my dxdiag here:
http://wikisend.com/download/205500/Win64_15319.txt http://wikisend.com/download/205500/Win64_15319.txt
Marian
Kevin_M_Intel
Hello Marian,
I am afraid I cannot access the website you posted.
Can you please post the dxdiag information here?
Marian
Hi,as below:
System Information
Time of this report: 6/17/2013, 23:19:51
Machine name: OLIVER
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: Intel
System Model: D33217GK
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz (4 CPUs), ~1.8GHz
Memory: 8192MB RAM
Available OS Memory: 7644MB RAM
Page File: 3452MB used, 4289MB available
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Sound Tab 1: No problems found.
Display Devices
Card name: Intel(R) HD Graphics 4000
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_20448086&REV_09
Display Memory: 1760 MB
Dedicated Memory: 512 MB
Shared Memory: 1248 MB
Current Mode: 2560 x 1080 (32 bit) (60Hz)
Monitor Name: Dell U2913WM (HDMI)
Monitor Model: DELL U2913WM
Monitor Id: DEL408A
Native Mode: 2560 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver File Version: 9.18.0010.3165 (English)
Driver Version: 9.18.10.3165
DDI Version: 11
Driver Model: WDDM 1.1
Driver Date/Size: 5/7/2013 17:22:46, 8632320 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-6BEF-4E00B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x20448086
Revision ID: 0x0009
Driver Strong Name: oem77.inf:IntelGfx.NTamd64.6.1:iIVBM_w7:9.18.10.3165:pci\ven_8086&dev_0166
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/...
TWeis2
Hi Kevin,
I have the same problem with my brand new HD 4600 on I7-4770K. Is there any solution for this?
Thanks, Tomer.
Nothing from them yet. I keep checking the drivers download page.
JRidd
Hi Kevin,
I applied the 3165 driver on two machines last night. Both are showing the same sign of not putting the monitors to sleep. dxdiag for both machines:
Machine 1
System Information
Time of this report: 7/6/2013, 09:23:57
Machine name: DESK-I7
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 02/18/13 15:00:12 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16080MB RAM
Page File: 4259MB used, 27897MB available
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Previously: Crashed in system information (stage 4). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Monitor Model: ASUS VH232H
Monitor Id: ACI23F1
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-A477-6821B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
SubSys ID: 0x01621849
Revision ID: 0x0009
Driver Strong Name: oem46.inf:IntelGfx.NTamd64.6.1:iIVBD_w7:9.18.10.3165:pci\ven_8086&dev_0162
Same problem here! My AMD just went out on me so I decided to run the on board graphics of my Asus Z87 Pro and Intel i7-4770k. The monitors go black but never go to sleep. Never had this issue before. Cannot find the older drivers as to which people speak but this is agitating to say the very least.
System Information
Time of this report: 6/19/2013, 00:30:49
Machine name: {REDACTED}
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 05/17/13 18:55:05 Ver: 10.07
Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 15296MB RAM
Page File: 1235MB used, 14060MB available
DxDiag Notes
Display Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Display Devices
Card name: Intel(R) HD Graphics 4600
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Model: NS-39L700A12
Monitor Id: BBY0042
Native Mode: 1920 x 1080(p) (59.991Hz)
Output Type: HDMI
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-AE7F-3EA5BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x85341043
Revision ID: 0x0006
Driver Strong Name: oem63.inf:5f63e534dd898f5e:iHSWD_w8:9.18.10.3165:pci\ven_8086&dev_0412
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_S...
System Information
Memory: 16384MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: BBY0042
Output Type: HDMI
DDI Version: 11.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0412
Revision ID: 0x0006
System Information
Memory: 16384MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: BBY0042
Output Type: HDMI
DDI Version: 11.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0412
Revision ID: 0x0006
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_St...
Kevin_M_Intel
Hello Marian/ scrosler,
This is a strange behavior on the new driver. I appreciate the feedback on this matter.
I will double check some more information and I will keep you posted.
Thanks Kevin. I got your email. Let me know if there is any other info needed. The new drivers give much better benchmarks!
