22659 ディスカッション
Monitor does not sleep with latest Intel GFX drivers
従業員
14,409件の閲覧回数
Hi, so I installed the latest drivers for my HD2500 GFX, I noticed they fixed the issues with the CYBCr resting itself but now my monitor does not go to sleep, it just goes to a black screen and stays powered on, anyone else have this problem, any fix available apart from using an older driver that have the CYBCr issue.
Cheers.
0 件の賞賛
61 返答(返信)
PLee26
ビギナー
2,487件の閲覧回数
Hi
Just came here as I have the same issue.
Intel board: DZ77BH-55K with Intel i7 3770, Windows 7 64Bit
DELL monitor connected by DisplayPort, second LCD monitor connected by DVI.
DELL monitor does not sleep or standby when told to by Windows, LCD monitor on DVI does.
Problem only with the latest Intel graphics drivers version 9.18.10.316, rolling back to the previous drivers and the monitor behaves normally and switches to standby.
By the way the new Intel Control panel is hideous using the Windows 8 style of all white space and huge graphics, I've stayed with Windows 7 for a reason!
Phil
Kevin_M_Intel
従業員
2,487件の閲覧回数
Hello All,
Can you guys try with one monitor connected to the motherboard? If possible test it with HDMI, DVI or VGA and/or other monitor.
Let me know.
従業員
2,291件の閲覧回数
Kevin, tried with 1 single monitor on HDMI and then one single monitor on DVI.
Yields the same non sleep results. Monitors go black but never go into deep sleep or shut off.
I'm also going to review the settings in BIOS to make sure its sleep mode friendly. I think I posted my stats earlier but I have a 4770k on an Asus Z89 Pro motherboard: http://www.asus.com/Motherboards/Z87PRO/ Z87-PRO - Motherboards - ASUS
Thanks and let me know if anything else I can try.
従業員
2,291件の閲覧回数
Just tried turning on all sorts of power saving functions of the BIOS. Something called ASPM and a few other things to deal with the PCIe Bus but none of the changed anything.
従業員
2,291件の閲覧回数
Look this is not an error on the user side , it's on Intel's side so they have to go and correct it, I hope they are doing that now.
従業員
2,291件の閲覧回数
Yes, I believe you are correct. I would have never seen this unless my AMD 6950 went out on me and am currently shopping for a replacement.
従業員
2,291件の閲覧回数
Running windows 8.1 preview and there is an Intel driver update version 9.18.10.3200, this through windows update, the monitor issue is fixed in this release. So should see an official release soon.
Kevin_M_Intel
従業員
2,291件の閲覧回数
Hello All,
I've been trying to replicate the problem you guys are having and I haven't been able to do so. I have tested different monitors (Dell, Asus and AOC) but everything is working just fine for me.
Please check both Dxdiag reports attached from the units I have been testing.
Based on these two reports, the Intel® driver 3165 is working fine from our side. I recommend you once again the operating system from scratch and installing also the monitor drivers. Try testing the system without installing the Windows* updates. Once this has been done, you can try installing windows updates and then testing the system again.
従業員
2,291件の閲覧回数
So you are asking to do a fresh install, no Windows Updates, install drivers and test?
I use Active@ Boot Disk so this will be no problem.
TWeis2
ビギナー
2,291件の閲覧回数
Did you try with Gigabyte Z87X-UD3H motherboard and screen connected to the HDMI port?
I have the driver version which you requested and problem persist. I can not install my Windows from scratch to prove that the driver has some bug. Here is my dxdiag info:
System Information
Time of this report: 7/3/2013, 21:30:38
Machine name: WEISBERG-PC
Operating System: Windows 8 Pro with Media Center 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z87X-UD3H
BIOS: BIOS Date: 05/16/13 21:47:33 Ver: 04.06.05
Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16278MB RAM
Page File: 8667MB used, 15033MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_D0001458&REV_06
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: SyncMaster P2770H/P2770FH (Digital)
Monitor Model: S27B350
Monitor Id: SAM08DC
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3165 (English)
Driver Version: 9.18.10.3165
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread
Driver Attributes: Final Retail
Driver Date/Size: 5/7/2013 17:22:46, 8632320 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-B57B-0AF0BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0xD0001458
Revision ID: 0x0006
Driver Strong Name: oem13.inf:5f63e534dd898f5e:iHSWD_w8:9.18.10.3165:pci\ven_8086&dev_0412
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=Vid...
従業員
2,291件の閲覧回数
Kevin, I can prove this is an issue with the Intel drivers...
If you will please.
1. Fresh install of Windows 8 x64 on Asus Z87Pro Motherboard, 4770k Processor, 16 Gigs of DDR3 2133 GSkill RAM and a Samsung 27" and a BestBuy Insignia 39" screen.
2. No drivers loaded.
3. Set monitor sleep time to 1 minute
4. Monitors DO sleep fine. This is using the "Microsoft Basic Display Driver"
5. Next install the Intel 3165 drivers, once again no other drivers loaded for motherboard.
6. Monitors do NOT sleep.
7. Re-image back to normal set up.
Links to DX Diag reports before and after...
Before ANY drivers here: https://dl.dropboxusercontent.com/u/31360541/INtel/DxDiag%20-%20No%20Drivers.txt https://dl.dropboxusercontent.com/u/31360541/INtel/DxDiag%20-%20No%20Drivers.txt
After JUST the display driver here: https://dl.dropboxusercontent.com/u/31360541/INtel/DxDiag%20-%20No%20Drivers.txt https://dl.dropboxusercontent.com/u/31360541/INtel/DxDiag%20-%20No%20Drivers.txt
I have no doubt that its the drivers. Let me know if there is anything else you can test. I have the liberty of dumping my OS at any time.
Im about to load up an Ubuntu stable release and see how that goes... Will let you know shortly.
従業員
2,291件の閲覧回数
And when I say fresh install, I am talking about first boot to desktop. No Windows updates, etc.
従業員
2,291件の閲覧回数
Fresh install of Ubuntu 12.04.2
No specific Intel drivers loaded. Gnome XScreensaver set to sleep monitors at 1 minute... (Blank Screen Only with power off checked)
Worked fine.
Updated Ubuntu (295 packages)....
No specific Intel drivers loaded. Screens sleep fine.
I hope this helps!
dboim
ビギナー
2,291件の閲覧回数
I have also experienced my Dell monitor not going into power save when connected with a mini DP to DP video cable to an ASUS z87-plus with a 4670 cpu running Win8. I swapped the DP cable for a DVI video cable and the problem stopped. It seems the common thing here is the video drivers since the problem occurs across multiple platforms using HDMI or DP cables. I will live with the DVI solution until a solution for this issue is found.
BKlei3
ビギナー
2,291件の閲覧回数
I can confirm this problem too running the latest driver , Intel HD4000, I5-3570K, Z77 chipset, Samsung 55" TV via HDMI
When uninstalling the latest driver, and installing the previous driver the problem goes away.
I've done it a couple of times now, and it's the same every time.
What I did notice was with the latest drivers, the HD4000 didn't recognize my TV.
With the working previous driver, it finds "Samsung Television".
With the new non-working driver, it's just "Plug and Play Monitor"
Could this be a hunch?
GAlle1
ビギナー
2,291件の閲覧回数
I hate to be a "me too", but this problem persists through the latest Win8 64 bit driver. Gigabyte Z87X-UD3H connected to HDMI, just like a previous poster - and the HDMI display will not sleep. I have two identical displays with one on the DVI port, which sleeps just fine. This is obviously a problem with the HDMI on these intel display adapters. Unfortunately, the only driver for me to roll back to is the previous one from March, which also has the issue.
I cannot believe that this problem has not been fixed yet!
JMast2
ビギナー
2,291件の閲覧回数
Hello I just wanted to chime in and report that I'm having the same issue as the other users in this thread. I have the Asus Z87-Pro motherboard with a i7 4770K processor with a Asus MX279 monitor. Now when the monitor is connected to VGA it will go into sleep state but once connected to HDMI monitor will not go into sleep state but will black the screen. Please let me know what I can do to help so this issue can be fixed for all of us.
Kevin_M_Intel
従業員
2,291件の閲覧回数
Hello All,
Thank you very much for the feedback. We appreciate all this information.
Please note that I will pass this information over to the corresponding department for them to take a look into this?
SJoo5
ビギナー
2,291件の閲覧回数
I do not know why, but I've had this problem
1. My previous system Intel DH67(B3) and Win8(x64).
2. Replace the motherboard (Zotac H87ITX-A-E), but did not reinstall the operating system if only I did not have this problem.
3. However, a new motherboard when you reinstall the operating system had a problem.
4. I'm in the old system disk [windows\system32] folder on the driver software update to resolve this problem was successfully fix it.
Not be helpful, but I'll tell you my information
Install the driver to get as soon as possible, please:)
System Information
Time of this report: 8/23/2013, 02:24:21
Machine name: KATE
Operating System: Windows 8 Pro K 64-bit (6.2, Build 9200) Service Pack 1 (9200.win8_gdr.130531-1504)
Language: Korean (Regional Setting: Korean)
System Manufacturer: Motherboard by ZOTAC
System Model: H87ITX-A-E
BIOS: BIOS Date: 06/18/13 14:46:59 Ver: 04.06.05
Processor: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8056MB RAM
Page File: 3268MB used, 6835MB available
Windows Dir: C:\WINDOWS
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_04128086&REV_06
Current Mode: 2560 x 1440 (32 bit) (60Hz)
Monitor Name: 일반 PnP 모니터
Monitor Model: Color LCD
Monitor Id: APP9CB5
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Driver File Version: 9.18.0010.3107 (English)
Driver Version: 9.18.10.3107
DDI Version: 11.1
Driver Date/Size: 4/12/2013 15:28:11, 8859648 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-15EF-1824BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x04128086
Revision ID: 0x0006
Driver Strong Name: oem15.inf:5f63e534dd898f5e:iHSWD0:9.18.10.3107:pci\ven_8086&dev_0412
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend Deinterla...
Kevin_M_Intel
従業員
2,277件の閲覧回数
Hi All,
We appreciate the feedback.
As mentioned before, this information will be forwarded to the corresponding department for future considerations.
JPoli
ビギナー
2,277件の閲覧回数
FWIW, I have a brand spanking new Gigabyte GA-Z87X-UD5H which uses the Intel HD Graphics 4600 chip/drivers. I have the same issue, where the monitor screen is merely blanked rather than going into power save mode, when Windows 7 power management turns off the display. Unfortunately, there doesn't appear to be any older drivers for me to try.
返信
