22936 Discussions
Monitor resolution 5120 x 1440 on UHD Graphics 620
Adam_W
I have a QSM 49" 32:9 Ultra Wide Curved monitor which I'm trying to run on my Asus laptop with an Intel(R) UHD Graphics 620 through a single HDMI.
The required resolution of 5120 x 1440 is not a selectable option.
Is there a way to run this monitor at the required resolution or do I need a dock and split across 2 HDMI's and use it as dual monitors?
Adam
Alberto_R_Intel
Hi Adam_W, Thank you very much for your response.
According to the specifications of the Intel® Core™ i7-8565U processor, the max resolution supported by the HDMI port with a straight connection not using adapters nor converters is 4096 x 2304@24Hz, as you can confirm here:
https://ark.intel.com/content/www/us/en/ark/products/149091/intel-core-i78565u-processor-8m-cache-up-to-4-60-ghz.html
Page 49:
https://www.intel.com/content/www/us/en/products/docs/processors/core/8th-gen-core-family-datasheet-vol-1.html
Based on the details shown in the Intel® graphics report, it states that the max resolution for your specific platform, as you mentioned previously is: 3840 x 2160 (24p Hz, 4K)
3840 x 2160 (25p Hz, 4K)
3840 x 2160 (30p Hz, 4K)
3840 x 2160 (50p Hz, 4K)
3840 x 2160 (60p Hz, 4K)
So, to answer your question, unfortunately, it will not be possible to use the 5120 x 1440 resolution on this machine, but you should be able to use 4096 x 2304@24Hz.
In the SSU document, we can confirm that the graphics driver currently installed on your computer is version 30.0.100.9955, which is a driver provided by Intel®.
We always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
In order to try to get the 4096 x 2304@24Hz resolution, we can try to do a clean installation of the graphics driver provided by ASUS, version V27.20.100.8681, following the instructions in the links below:
https://www.asus.com/us/Laptops/For-Home/Everyday-use/ASUS-X509/HelpDesk_Download/?model2Name=ASUS-Laptop-15-X509FA
Or, even though the Intel® graphics drivers are generic and they might or might not work with your platform, for testing purposes, we can do a clean installation this time of the Intel® generic graphics driver version 30.0.101.1069 and then verify if now you are able to use the 4096 x 2304@24Hz resolution:
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html?
We also advise to get in contact directly with ASUS support to make sure the latest BIOS version is currently installed in your laptop or to gather the instructions on how to do that:
https://www.asus.com/support/
Albert R.
Alberto_R_Intel
Adam_W, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance in reference to your question, we just wanted to confirm a few details about your system:
What is the model of the laptop?
Is this a new computer?
When did you purchase it?
Were you able to use the 5120 x 1440 resolution on this same computer before with this or with another monitor?
What is the max resolution that you are allowed to select?
When did the issue start?
Did you make any recent hardware/software changes?
Which Windows* version are you using?
While the monitor is connected to the laptop, please run and attach the SSU report and the Intel® graphics report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Adam_W
Hi Albert,
Thanks for your response. See below answers to your questions:
What is the model of the laptop? See attached
Is this a new computer? No it's 2 years old.
When did you purchase it? October 2019
Were you able to use the 5120 x 1440 resolution on this same computer before with this or with another monitor? No I've never used a monitor like this before.
What is the max resolution that you are allowed to select? 3840 x 2160
When did the issue start? I received a new ultra wide monitor at work last week and have been unable to get the correct resolution.
Did you make any recent hardware/software changes? No. I updated the version of graphics drive last week whilst trying to troubleshoot this screen issue.
Which Windows* version are you using? 10
Does the problem happen at home or in the work environment? I only have the ultra wide monitor at work.
Alx24
New Contributor II
It is worth noting that 128 bytes Block 1 and Block 2 of EDID here are exactly the same
Intel® UHD Graphics 620 - Monday, 22 November 2021.txt
Raw EDID:
00 FF FF FF FF FF FF 00 31 03 FF FF 01 00 00 00
1B 1F 01 03 80 78 22 78 2A F8 E5 B3 49 3B AF 25
13 50 54 BF EF 80 71 4F 81 C0 81 40 81 80 95 00
A9 C0 B3 00 D1 C0 50 D0 00 A0 F0 70 3E 80 30 20
35 00 AA 50 41 00 00 1A 00 00 00 FD 00 30 78 48
B2 3C 00 0A 20 20 20 20 20 20 00 00 00 FC 00 51
34 39 43 48 51 42 2D 44 51 48 44 0A 00 00 00 FF
00 30 30 30 30 30 30 30 30 30 30 30 30 30 02 09
02 03 46 F1 53 01 02 03 04 05 90 11 12 13 14 1F
20 22 3F 5D 5E 5F 60 61 23 09 7F 07 83 01 00 00
6D 03 0C 00 20 00 38 3C 20 00 60 01 02 03 67 D8
5D C4 01 78 80 03 E3 05 E3 01 E4 0F 00 80 01 E6
06 07 01 61 60 26 6A 5E 00 A0 A0 A0 29 50 30 20
35 00 AA 50 41 00 00 1A 6F C2 00 A0 A0 A0 55 50
30 20 35 00 AA 50 41 00 00 1A 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3F
For example, EDID of 5K displays with a resolution of 5120x1440:
https://github.com/linuxhw/EDID/tree/master/Digital/Samsung/SAM0F9C
in which resolution 5120x1440 is located in the DisplayID extension and requires a frequency of 60Hz.
Alx24.
Alx24
New Contributor II
It is worth noting that each of the two identical expansion blocks Block 1 and Block 2 of EDID
contains the corresponding HDMI 2.0 "Vendor Specific Data Block HDMI 2.0"
which has additional stereo-parameters
"Supports 3D Independent View"
"Supports 3D Dual View"
"Supports 3D OSD Disparity"
Vendor Specific Data Block HDMI 1.4
IEEE OUI: 000C03
Source Physical Address: 2000
Supports ACP, ISRC1, ISRC2
Supports 48 bits/pixel (16 bits/color)
Supports 36 bits/pixel (12 bits/color)
Supports 30 bits/pixel (10 bits/color)
Supports YCbCr 4:4:4 Deep Color
Supports Dual DVI
Max TMDS Clock Rate: 300 MHz
Video/Audio Latency Fields Present
IEEE OUI: C45DD8
Version: 1
Max TMDS Clock Rate: 600 MHz
Supports SCDC
Supports SCDC Read Request
Supports Scrambling for less <=340MHz
Supports 30 bits/pixel (10 bits/color) for Deep Color YCbCr 4:2:0
Supports 36 bits/pixel (12 bits/color) for Deep Color YCbCr 4:2:0
Supports 48 bits/pixel (16 bits/color) for Deep Color YCbCr 4:2:0
DTD (Detailed Timing Descriptor) in each extension block Block 1 and Block 2
contains timing details for 2560 x 1440 at 60 Hz, 2560 x 1440 at 120 Hz
Pixel Clock: 241.7MHz / 60 Hz
Horizontal Active: 2560
Horizontal Blanking: 160
Vertical Active: 1440
Vertical Blanking: 41
Horizontal Sync Offset: 48
Horizontal Sync Pulse: 32
Vertical Sync Offset: 3
Vertical Sync Pulse: 5
Horizontal Display Size: 1194
Vertical Display Size: 336
Horizontal Border: 0
Vertical Border: 0
Interlaced: false
Stereo Mode: 0
Sync Type: 3
2-Way Line-Interleaved Stereo: false
(241700000 / (2560 + 160)) / (1440 + 41) - 60 Hz
Pixel Clock: 497.75MHz / 120 Hz
Vertical Blanking: 85
Vertical Border: 0
Interlaced: false
Stereo Mode: 0
Sync Type: 3
(497750000 / (2560 + 160)) / (1440 + 85) = 119
Quite possibly for the display 2 x HDMI 1.4 ( 2560 x 1440 at 60 Hz )
Alx24.
Alberto_R_Intel
Hello Adam_W, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Adam_W
Hi Albert,
Sorry but I don't understand the information provided.
What am I required to do and how can this issue be resolved, if possible?
Adam
Alberto_R_Intel
Page 49:
Albert R.
Adam_W
Hi Albert,
Thank you for your detailed response and assistance.
Adam
Alberto_R_Intel
Hi Adam_W, You are very welcome, thank you very much for your response.
We are glad to know that the information provided previously was useful and helpful for you.
Any other inquiries, do not hesitate to contact us again.
Albert R.
Harlock
Kind of late but I can use 5120 x 1440@60hz over DP via the usb-c port on my inspiron 7373,
over hdmi it shows the resolution available to pick but it doesn't work.
3840x1080 does work over hdmi so there is no issue with the aspect ratio.
