i have a problem:
The above NUC only allows UHD Resolution with 30HZ an no HDR on my HDR-TV. The MINI-PC i had before had no problem with 3840x2160p@60 HDR. It even says the TV doesn't support HDR!
Is the ARC770M somehow broken?
The TV is connected via the HDMI-Port (it has no DP).
Do you have an idea what could be the problem here?
Mathias
See the attached image of ARC Control
found the problem: The HDMI cable doesn't seem work with the NUC. After using another one everything works fine.
Thanks and sorry for the inconvenience.
Mathias
