23263 Discussions
NUC8I5BEH1 HDMI to Displayport Adapter Does Not Work
oZo61
I am trying to use a NUC8I5BEH1 mounted on a VESA bracket to a Dell monitor. The monitor has a Displayport connection, not an HDMI. I bought an adapter cable from Amazon, but there is no video going to the monitor. I tried a longer HDMI cable with a separate Displayport adapter, and there is still no video signal going to the monitor.
I tested the monitor on my desktop PC using a standard Displayport cable from a RTX 3070 with no issues.
I use the NUC8I5BEH1 with an HDMI cable to my Samsung 28" 4K monitor with no issues.
Anyone have any idea why the adapter/cords aren't working?
Thank you for looking.
MUC
Honored Contributor I
Adapters for video signals with different transmission protocols are almost always unidirectional, i.e. they only work in one direction. There are many from DisplayPort > HDMI but almost none from HDMI > DisplayPort.
However, you do not need a converter for the video protocol. Please simply use this cable and connect it to the USB-C/Thunderbolt port on your NUC8BEH. Your device can output a DisplayPort signal via the Thunderbolt port that does not need to be converted and can be fed directly into the monitor via the DisplayPort connector.
MUC
oZo61
Thanks, I didn't know that about the HDMI/Displayport.
I already have a cable as you mention and I was going to use it if I couldn't get it to work the other way. So looks like I will dig it out and use it.
