23100 Discussions
Need for Speed the Run, Battlefield 3 slow performance on newer drivers
I have a HP laptop with I3-2330 cpu with intel hd 3000 graphics card, 6gb of ram and windows 7 64-bits.
Any driver above 2761 gives me very slow performance in need for speed the run and battlefield 3, making these games unplayable. I read in a discussion that there is some power saving features in newer drivers that makes some games slower, and all we have to do is to select High Performance under power saving settings. I report that selecting High Performance in power saving settings does not make these two games run any faster, they are still very slow.
I was hoping for better performance with every new driver release, but was disapointed with the performance of all driver versions from 2792 to 2867. I hopw future driver releases will correct this issue. Thank you.
DArce
Valued Contributor III
We appreciate your feedback on this matter. We will make sure your comment reaches the proper department for the appropriate consideration.
Please keep in mind that BF3 is currently marked as playable using Intel® HD Graphics 4000 with al patches from EA.
Unfortunately, I still get really slow performance on need for speed the run and battlefield 3. I tried to select High performance mode in my power mangement settings, but it had no effect at all.
UPDATE: I reinstalled the 2875 drivers, and now Battlefield 3 runs as good as in older drivers, but I still get slow performance in need for speed the run.
NICHOLAS_F_Intel
Hi user202.11. I'm glad to see that there was at least performance improvement in BF3. Let's see if we can't diagnose some issues you're having with NFS now.
If you've got time, I'd like to ask some questions about your system.
-Can you provide some detail about the brand/speed of your RAM?
-A screenshot of your in-game graphics settings.
-A reference for what FPS you are getting in game (either from the in-game user interface, or FRAPS, etc)
-A copy of your Intel® Graphics and Media Control Panel™ report (Ctrl + Alt + F12 to open CUI, navigate to the "Options and Support Tab" -> Information Center -> Save and attach to reply window).|
Let me know if you need any help obtaining this information!
Thanks!
-Nic
Info about RAM:
4Gb SODIMM 1333Mhz Samsung
2Gb SODIMM 1333Mhz ELPIDA
for a total of 6gb
In game Settings:
I have all possible advanced settings set to LOW.
Vsync is off
resolution is 1280x720
the game runs full screen
With Fraps I get 11-12 fps with drivers version 2875, even with high performance profile selected in power management settings.
I get 17-26 fps with drivers version 2761.
Graphics and Media Control Panel™ report (with driver version 2761) :
Intel(R) HD Graphics 3000
Report Date: 11/15/2012
Report Time[hh:mm:ss]: 13:38:06
Driver Version: 8.15.10.2761
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: French (Canada)
DirectX* Version: 11.0
Physical Memory: 6091 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 133 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2195 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2089.0
Current Graphics Mode: 1600 by 900
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 15,35 inches
Vertical: 08,66 inches
Monitor Supported Modes:
1600 by 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 0D AF 19 17 00 00 00 00
05 13 01 03 80 27 16 78 0A 08 05 9D 58 53 97 29
15 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 1C 2A 40 54 61 84 1A 30 30 20
35 00 7E D7 10 00 00 18 00 00 00 FE 00 4E 31 37
33 4F 36 2D 4C 30 32 0A 20 20 00 00 00 FE 00 43
4D 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 4E 31 37 33 4F 36 2D 4C 30 32 0A 20 20 00 AD
HBara3
i have download this drivers bu i cant install it it is sowing me error this pc has not menimum requirment for install this software i have try all drivers with thi link
i have intel hd graphic i3 pross hp 430 laptop
HBara3
Derar Sir or Madam
I have Download This Drivers and Try To install But It's Giving Me Error
this Error Attached
And I Have Attache My PC Detail All so and attached current install drivers
detail Pls Help me For This Problem
NICHOLAS_F_Intel
Download the .zip version of the 3345 driver. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&keyword=3345%5c&DownloadType=Drivers&lang=eng Download Center
Then try to install it via the Manual Driver Installation method. Information on how to do that is located here; http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics — How to manually install a driver in Microsoft Windows* 7
Let me know if this works or not.
-Nic
MSchm21
He seems to have an i3-370M which is based on Clarkdale with an old Intel HD graphics. Driver 3345 is incompatible. Afaik 15.22 is supported, all newer driver are incompatible. When you ask questions don't forget CPU model and OS configuration. Notebook model is not enough.
HBara3
i dear sir
as per your post i have tried all thinks to install specified drivers in link
i have tried to install from update and tried to install from pick drivers
i have uninstall my graphic driver and try to install it bu i cant install this drivers
there is snap shot of my cpu detail, os detail and main board detail
all so i have attached error when i try to install this drivers
pls help me sir i am a technical person pls tell me this drivers support my system or not
HBara3
i have try find automatically from intel site it's giving me this result
HBara3
HBara3
can i install it or not pls give me ans yar
HBara3
why not give me reply
MSchm21
No you can't. This is a Clarkdale with driver support up to 15.22.
