22649 Discussions
Need help with the Aspect ratio options
Hi everybody!
I'm using Intel 82945G Express Chipset Family. My monitor resolution is 1366x768
So whenever i run a 1024x768 program, two black borders will appear on the left and right of the screen
But now, it expand to the whole screen instead, make the graphics look 'fat'
I selected 'Maintain aspect ratio' as below, but it didn't work
http://nt9.upanh.com/b1.s11.d1/0a7d05b77af2ef0f2684fecca9ce4176_51778689.untitled.jpg[/IMG]
Can anyone help me out?
Many thanks...
DArce
Valued Contributor III
Please bear in mind that this product has reached its End of Interactive Support so Intel no longer provides interactive support for this product via telephone, chat or e-mail.
I suggest that you uninstall the driver installed and try using the generic driver posted on the following URL:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=Intel%C2%AE+82945G+Express+Chipset&ProdId=2102&LineId=1100&FamilyId=39 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=Intel%C2%AE+82945G+Express+Chipset&ProdId=2102&LineId=1100&FamilyId=39
In addition check on the settings of the application being used and make sure that this is not being affected by a setting on the software application itself.
Oh thanks for helping me
I did exactly what you said but nothing changed
DArce
What is the name of the applications you are having this issue with?
Could you please send the graphics report generated by the Intel(R) Graphics Media Accelerator control panel?
For more information on how to get this report, please check this article:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
I have trouble with every full screen applications, such as Age of Empire
here is the reportIntel(R) Graphics Media Accelerator Driver Report
Report Date: 01/24/2013
Report Time[hr:mm:ss]: 01:03:04
Driver Version: 6.14.10.4926Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)Default Language: KoreanDirectX* Version: 9.0Physical Memory: 2039 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 10 MB
Processor: x86 family 6 Model 23 Stepping 10Processor Speed: 2500 MHZVendor ID: 8086Device ID: 2772Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) 82945G Express Chipset FamilyVideo BIOS: 1374
Current Graphics Mode: 1366 by 768 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Display Type: AnalogGamma Value: 2.20DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 16.0 inches
Vertical: 9.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 ff ff ff ff ff ff 00 10 ac 3e a0 4c 4b 46 31
0c 13 01 03 0e 29 17 78 ee ee 95 a3 54 4c 99 26
0f 50 54 a5 4a 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 66 21 56 aa 51 00 1e 30 46 8f
33 00 9a e6 10 00 00 1e 00 00 00 ff 00 4e 34 32
31 47 39 33 4c 31 46 4b 4c 0a 00 00 00 fc 00 44
45 4c 4c 20 53 31 39 30 39 57 0a 20 00 00 00 fd
00 38 4b 1e 53 09 00 0a 20 20 20 20 20 20 00 d1
* Other names and brands are the property of their respective owners.
DArce
Thank you for the information, let me further investigate on this and get back to you.
JTerr5
This is honestly the most annoying bug in the software. Any time you create a custom resolution at 4:3, you have NO OPTION to maintain aspect ratio. It's complete crap. The driver always decides to stretch full screen.
Please make this the # 1 thing to fix. Make it so we can MAINTAIN ASPECT RATIO for custom resolutions.
I'm purposely bumping all aspect ratio questions so you programmers know how serious of an issue this is.
Also fix the limited 60hz problem for monitors that can go to 120hz. That's another huge bug.
Allan_J_Intel1
This problem has been reported here: /thread/51712 Where is "maintain aspect ratio" for Intel HD 4000 on Windows 8.1?
Allan.
