22643 Discussions
New HP EliteDesk 800 G3, with Intel HD Graphics 530 doing BSODs watchdog.sys, ntoskrnl.exe, dxgmms2.sys
RZotz
Débutant
11 622 Visites
I keep getting BSODs on this newly built machine. No extra graphics card, just the internal one. I've swapped out the intel graphics drivers for the latest ones, and still having the issue. Here is the BSOD info attached.
Anyone come across this that can help?
0 Compliments
7 Réponses
RZotz
Débutant
9 475 Visites
This is a 6th gen i5-6500 cpu.
0 Compliments
Employé
9 475 Visites
Hello nizmoz,
I understand that you are getting blue screen issues with your system even when the system is a new build, I apologize for any inconvenience.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
0 Compliments
Employé
9 474 Visites
Hello nizmoz,
Thank you for your response,
I was checking the information and also the attachment with the error shown during the blue screen and the problem does not seem to be related to the graphics. It seems to be more related to the processor or else the operating system.
Nevertheless, as a troubleshooting step and for testing what we can do is to update the graphics driver. Please download the ".zip" file from the following link:
https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=88345 https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=88345
Once the "zip" file is downloaded please follow the next steps:
1 - Unzip the file to a designated location or folder.
2 - Right-click Windows Start icon and open Device Manager.
3 - Click Yes when prompted for permission from User Account Control.
4 - Expand the Display adapters section.
5 - Right-click the Intel® graphics entry and select Update Driver Software.
6 - Click "Browse my computer for driver software".
7 - Click "Let me pick from a list of device drivers on my computer".
8 - Click "Have Disk".
9 - Click "Browse".
10 - Access the designated location or folder, and access a folder called "Graphics".
11 - Select the file called "igdlh64" or "igdlh".
12 - Click Open, then click OK, and finally click Next. Drivers are now being installed.
13 - Reboot your computer
If after this the issue persists then I would strongly suggest you to contact either the manufacturer of the computer (HP) or else Microsoft to have a look at the current BSOD situation.
David V
0 Compliments
Employé
9 474 Visites
Hello nizmoz,
If that is the case then I am really glad I was able to help with what I could. For now then I will proceed to close this request, however, if you need any more help do not hesitate to reply for further help.
David V
0 Compliments
RZotz
Débutant
9 475 Visites
David, here is what you requested. Thanks!
System Information
Time of this report: 3/2/2018, 13:28:53
Machine name: ABTSP087
Machine Id: {66803FF7-4E81-4647-94EC-CD199649B7F4}
Operating System: Windows 10 Enterprise 2016 LTSB 64-bit (10.0, Build 14393) (14393.rs1_release.180209-1727)
Language: English (Regional Setting: English)
System Manufacturer: HP
System Model: HP EliteDesk 800 G3 SFF
BIOS: P01 Ver. 02.15
Processor: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 16384MB RAM
Available OS Memory: 16232MB RAM
Page File: 6567MB used, 12095MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: The file Unknown is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 530
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_1912&SUBSYS_8299103C&REV_06
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8243 MB
Dedicated Memory: 128 MB
Shared Memory: 8115 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Dell U2412M(DisplayPort)
Monitor Model: DELL U2412M
Monitor Id: DELA07B
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: Displayport External
Driver Name: C:\Windows\System32\DriverStore\FileRepository\ki125652.inf_amd64_bc4bd98093bb89ac\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\ki125652.inf_amd64_bc4bd98093bb89ac\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\ki125652.inf_amd64_bc4bd98093bb89ac\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\ki125652.inf_amd64_bc4bd98093bb89ac\igd12umd64.dll
Driver File Version: 23.20.0016.4849 (English)
Driver Version: 23.20.16.4849
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 10/26/2017 6:00:00 PM, 53357560 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-5A52-11CF-7D61-89A2BDC2DA35}
Vendor ID: 0x8086
Device ID: 0x1912
SubSys ID: 0x8299103C
Revision ID: 0x0006
Driver Strong Name: oem8.inf:5f63e53470659c00:iSKLD_w10_DS:23.20.16.4849:pci\ven_8086&dev_1912&subsys_8299103c
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_Stretch...
0 Compliments
Employé
9 475 Visites
Hello nizmoz,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
0 Compliments
RZotz
Débutant
9 474 Visites
I'm sorry that I haven't replied, been extremely busy. I've been monitoring the computer after I ran HP Soft Paq and had it update everything again even though we downloaded the latest drivers from HP site. It seems to have stopped the issue from happening. I didn't need to run through your process. But thank you anyways!
0 Compliments
Répondre
