23054 Discussions
Newer drivers break UHD 770 suport and keep force installing through windows update
rabithole1234
I have 3 monitors connected to an RTX 4090 and a 4th connected to my iGPU. Whenever my monitors go to sleep, there is a 70% chance the monitor connected to the iGPU won't wake up from sleep. If it does wake up, it causes the monitors connected to my 4090 to continually flicker and briefly lose signal until I restart all graphics drivers with ctrl shift and b.
This seems to be a problem on every driver beyond 4824 which is on my motherboard's support page. The issue is that Windows continues to update this driver to a new version that causes these issues. Is there a way to force Windows to stop updating this driver specifically?
AlHill
Use the wuShowHide utility from Microsoft (attached).
Download and install the driver you want.
Reboot.
Run wuShowHide.diagcab and block/hide the  update you do not want.
[Intel, like it or not, NUCs did exist]
AlHill
Reboot.
rabithole1234
