22660 Discusiones
No HDR Options on Intel Graphics 630
DSera
Nueva usuaria
28.301 Vistas
Dear all,
I am sorry to bother you again, but I have another issue with the Intel Graphics 630 Controller. The HDR option is off and I cannot actívate it. I cannot stream in HDR either. I have a Sony XD90 Series, which is fully compatible with HDR. I tried to play a HDR game on the Ps4 Pro and it Works perfectly. I also tried to connect the computer with my dedicated graphic card (Nvidia Geforce GTX 980ti), and the option "Activate HDR" is active. COnversely, I do not have this option when I use the Intel graphics 630 driver. I checked the fórum and it seems that I am not the only one to have this problem, but it has not been solved yet.
Obviously, I have the latest Intel and Windos driver, the Tv is connected via HDMI and I am using the integrated video driver.
Please find attached all the information that you need to address this issue.
danser86
0 kudos
26 Respuestas
DSera
Nueva usuaria
3.355 Vistas
I have exactly the same issue as rostan242. Refreshing is available now @60hz, but no HDR option.
ANy suggestion on how to enable HDR?
Many thanks,
danser86
DSera
Nueva usuaria
3.355 Vistas
Dear Ronald,
Many thanks for your assistance. I would really appreciate it.
Best,
danser86
arost
Principiante
3.355 Vistas
it seems to me that I found a solution for the motherboard which has hdmi 2.0 evga z370 classiefied K
the only problem I can not find her in stores in europe I wrote an email to evga if they can send to UK or Europe I am waiting for a response
Dear Ronald, Can you check if this motherboard is OK
RonaldM_Intel
Moderador
3.355 Vistas
Hi again rostan242
I'm looking at the https://www.evga.com/products/product.aspx?pn=134-KS-E379-KR EVGA Z370 Classified K, part# 134-KS-E379-KR's specifications and https://www.evga.com/support/manuals/files/134-KS-E379.pdf manual, unfortunately I do not see a clear indication whether that's HDMI 2.0 or HDMI 2.0a.
As previously mentioned, for HDR support we need HDMI 2.0a (achieved via LSPCON converter).
I searched in the manual for any reference to 'HDR' and only got 1 hit, and was in the Glossary of terms (page 136), so I hope you'll understand why I'm not comfortable saying whether this one would work or not. The best approach is https://www.evga.com/about/contactus/ asking EVGA directly, which I just did by the way. Once I have a reply from them I'll let you know.
Ronald M.
Rruiv
Principiante
3.355 Vistas
Hi Ronald,, can you help me I have MSI ge627re apache pro and TV LG OLED55C7V and I would like to have HDR active but I have the same problems the others. Could you help me with a adaptor I can use or other solution
Thank you.
RonaldM_Intel
Moderador
3.355 Vistas
Hi Ronaldo12,
Unfortunately I haven't been able to find any adapter that successfully lets HDR work correctly, thus at the moment only direct HDMI 2.0a output or DP 1.3 are recommended.
I checked the https://www.msi.com/Laptop/GE62-7RE-Apache-Pro/Specification specifications for the MSI GE62 7RE Apache Pro and it seems the HDMI port is 1.4 (maximum resolution of 4K@30hz). There is no information on the DisplayPort (DP) port specification, so I'll suggest checking with MSI for more details concerning the DP output. More so, it seems this laptop can come equipped with a Discrete graphics card (i.e. GeForce® GTX 1050 Ti), and there is a possibility that this card may be connected to one of the video ouputs (e.g. DisplayPort). I can't tell for sure as that is up to MSI's own hardware implementation.
Ronald M.
Responder
