22660 Diskussionen
No audio over HDMI - UHD730
Risto82
Einsteiger
1.130Aufrufe
PC specs:
Motherboard: Biostar Z590MHP
CPU: intel i5 11400
GPU: intel i5 integrated UHD730
RAM: 16MB, 3200
SSD: PC SN740 NVMe WD 256GB
Windows 10. 64bit.
Problem:
No audio when PC is connected to TV via AVR over HDMI. Video works.
Notes:
Audio works when headphones are connected to PC via 3.5 mm jack. So integrated audio card works.
PC and AVR are connected directly by HDMI cord, no other connections in between. Audio works with other PC-s (laptops) connected behind the same HDMI. So it is not HDMI cable, connections nor AVR settings issue.
Under device manager the PC recognises AVR as monitor but not as audio device. Other PC-s connected recognise AVR both as monitor and audio device.
In BIOS HD audio is enabled.
Have tried several audio drivers: Realtek, Intel, Windows generic. Nothing works.
Have the latest graphics drivers + done a clean install of the drivers as instructed in intel forum somewhere.
All win10 updates have been done.
Have tried win11, same issue. Reverted back to win10.
Intel processor diagnostic tool: all passed.
Intel SSU report is created, but what is the relevant part I should look at in order to diagnose the problem.
Any ideas or suggestions what to try?
1 Lösung
Risto82
Einsteiger
1.082Aufrufe
I have found a solution, that fixed the issue for me. I reset BIOS settings to factory settings and now it works.
Lösung in ursprünglichem Beitrag anzeigen
3 Antworten
ACarmona_Intel
Mitarbeiter
1.098Aufrufe
Hello Risto82,
You have mentioned that you have already generated your SSU report; is it possible that you can share it with us so we can further check important details on your system? such as your system driver versions, etc.
We look forward to your response!
Carmona A.
Risto82
Einsteiger
1.083Aufrufe
ACarmona_Intel
Mitarbeiter
1.054Aufrufe
Hello Risto82,
Thank you so much for the update, and I am glad to hear that you have already fixed the issue by restoring your BIOS settings to factory settings.
Since you will no longer need my assistance, I will now close our case, and for additional information, please submit a new question as this thread will no longer be monitored.
By the way, I truly appreciate that you have shared the solution that has fixed the issue. I hope other community members will find our thread helpful.
Bye for now, and have a great day!
Carmona A.
Antworten
