22643 Diskussionen
No existe OpenGL o no tiene los últimos drivers instalados
NDali
Einsteiger
2.005Aufrufe
Recientemente acabo de instalar el driver gráfico de Intel pero no puedo ejecutar juegos porque me dice que no hay API OpenGL
7 Antworten
AlHill
Superuser
1.954Aufrufe
You have the latest driver installed.
You have OpenGL 4.6.
What game is telling you that you have a problem?
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
W10 2004, W10 May 2020, W10 20H1, W10 19041 - A rose, by any other name, still smells.
AlHill
Superuser
1.954Aufrufe
No need to start another thread. Just provide the ssu support file I asked for above.
Doc
NDali
Einsteiger
1.954Aufrufe
This is the file with the results.
AlHill
Superuser
1.954Aufrufe
I cannot see anything wrong. You have the latest Intel graphic driver, your OS is current. You do have dual graphics.
is your device a laptop? What application is reporting that your OpenGL is a problem?
Doc
NDali
Einsteiger
1.954Aufrufe
I use pc, a few days ago I was using 2 gpu (Intel and Nvidia) to perform personal performance tests, I am using iGPU in this case but I cannot open games like Asphalt 9 legend (microsoft store) it just closes like all other games, I tried other programs that OGL requires and I ran into the problem that I only have opengl 1.1 (GDI Generic) installed. I have the latest driver installed thanks to the intel scan tool but that is my only problem, I can use other normal APIs like Vulkan. I use intel core i5 8600k according to the web of intel supports ogl 4.4
AndrewG_Intel
Mitarbeiter
1.954Aufrufe
Hello NDali
We are checking this thread and we would like to know if you need further assistance. Should you have additional inquiries, please let us know.
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded in this Intel Community.
Andrew G.
AndrewG_Intel
Mitarbeiter
1.954Aufrufe
Hello NDali
We have not heard back from you so we will proceed to close this thread. If you need further assistance please post a new question.
Andrew G.
Antworten
