22695 討論
Not able to install Intel Graphics driver on Windows 10 2016 x64, the default Microsoft Basic Display Adapter is installed.
MMani7
初學者
3,193 檢視
I am trying to install the Intel Graphics card driver version v15.40.25.4463 on a Windows 10 IoT Enterprise 2016 x64 machine. By default, Microsoft Basic Display Adapter is installed and whenever I try to install the Intel graphics, it says the installed driver is up to date.
Can you tell me how to install the Intel Graphics driver on the machine?
I tried to install the latest driver but couldn't succeed.
Processor: Intel Atom E3826
Graphics adapter Hardware ID: PCI\VEN_8086&DEV_0F31&SUBSYS_72708086&REV_11
Appreciate your help!
Prabu
0 積分
1 解決方案
Stefan3D
榮譽貢獻者 II
2,204 檢視
Driver build 4463 is for 4th generation and beyond.
Your Valleyview is 3rd generation.
Build 4425 from here: https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33- Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]
supports your GPU:
DriverVer=04/04/2016,10.18.10.4425
; Windows 10.0 Install
%iVLVGMT0% = iVLV2M_w10, PCI\VEN_8086&DEV_0F31
在原始文章中檢視解決方案
5 回應
Stefan3D
榮譽貢獻者 II
2,205 檢視
supports your GPU:
MMani7
初學者
2,204 檢視
Thanks Stevan3D, that solved my issue.
員工
2,204 檢視
Hello Prabu,
If you go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed. The last four digits will tell you the version. Let me know those numbers so I can cross check with our https://downloadcenter.intel.com/ Drivers & Software and let you know if you have the latest.
Amy.
MMani7
初學者
2,204 檢視
Hi Amy,
Thanks for the reply. As suggested by Steven3D in the previous post, the driver for Graphics was installed correctly.
"Build 4425 from here: https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33- Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33] "
員工
2,204 檢視
/thread/108986 Prabu good to hear!
If you need further assistance let us know.
Amy.
回覆
