I'm using an Intel Nuc Pro 14, with Ubuntu 24.04.
In Windows, I can use the full resolutions of my 2 HDMI screens: 2560x1080@60Hz
However, in Ubuntu, it seems the support for this resolution is missing from the driver, and it tops out at 1920x1080@60Hz for both screens, leading to black bars on both sides of the screen.
The listing for this PC explicitly mentions support for Ubuntu 24.04. So I expect this *should* work, given that in Windows11, the hardware has no issue with it.
Kind regards,
Jeffrey
- « Previous
- 1
- 2
- Next »
It's however not a valid test. The monitor you tested, is 16:9. Not 21:9.
That's exactly the point of this. Monitors fall back to 16:9; and 21:9 is failing on Linux.
Please try with a 21:9 display. You will see the issue is there.
Kind regards,
Jeffrey
- « Previous
- 1
- 2
- Next »
