22889 Discussions
Only able to adjust brightness once I plug in my computer- HP EliteBook x360 1030 G2
APass1
I am able to adjust the percent of the brightness with the keys and slider, however, the brightness change only applies once I plug my computer into the charger. I have updated the graphics and display drivers multiple times and nothing seems to work. Please help, thanks!
AlHill
Use the drivers provided by HP.
Doc
APass1
Thanks for the suggestion! I have tried this a couple times and it has not worked either ​
AlHill
Then, contact HP for support of their device. They are the integrator, they made the device, and they supposedly tested the drivers they provide. Additionally, these drivers have likely been modified by HP. You may also want to update the HP bios to the latest they have available.
When you purchased this device, you paid HP for support. Make them earn it.
Doc
