23099 Discussions
Open GL not supported with graphics Intel® 82945G on Windows 7 Home Premium 64-bit
khuyn4
On Win XP, my graphics is Intel® 82945G (driver v6.14.10.4926), it works well with no Open GL error in applications Counter-Strike 1.6
On Win 7 Home Premium 64-bit, my graphics (lastest driver v15.12.75.4.64.1930) not support Open GL in applications Counter-Strike 1.6.
My computer model is Gateway E6500. I tried with model Asus P5GC-MX and it all say not support Open GL.
My dxdiag report with Gateway E6500 :
System Information
Time of this report: 1/5/2015, 00:48:04
Machine name: GW-E6500-W7
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: 05DT049_
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) D CPU 3.40GHz (2 CPUs), ~3.4GHz
Memory: 4096MB RAM
Available OS Memory: 3574MB RAM
Page File: 1163MB used, 5981MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
Kevin_M_Intel
Hello bjtip,
The reason of this is that the latest Operating System this controller can support is Windows Vista. Here you can confirm this information:
http://www.intel.com/support/graphics/sb/CS-034343.htm?wapkw=cs-034343 http://www.intel.com/support/graphics/sb/CS-034343.htm?wapkw=cs-034343
The Intel® 82945G supports up to OpenGL 1.4 and DirectX 9.0. Here you can confirm this information:
http://www.intel.com/support/graphics/sb/cs-033757.htm http://www.intel.com/support/graphics/sb/cs-033757.htm
Based on your description and as per information provided above, it seems the Operating System may not be working properly and using unsupported Operating Systems may cause unknown and unexpected behaviors.
Kevin M
