23818 Discussions
OpenGL ES Error with Intel HD Graphics 530
I have problems with some Magix-Software. When starting the software, I get the error "OpenGL ES Error Can't find the name of Intel ICD OpenGL driver". I use an onboard Graphic card (Intel HD Graphics 530) and have the driver version 21.20.16.4542 installed. What can I do to solve this problem?
Stefan3D
To check correct driver installation run https://www.saschawillems.de/?page_id=771 OpenGL hardware capability viewer with GLES context and compare to http://opengl.gpuinfo.org/gl_generatereport.php?reportID=1493 > this report <</a>
I've checked it with the OpenGL hardware capability viewer and made an upload with my report (http://opengl.gpuinfo.org/gl_generatereport.php?reportID=1631 OpenGL Hardware Database - © 2011-2015 by Sascha Willems ).
The comparison of the mentioned report and my report (http://opengl.gpuinfo.org/gl_comparereports.php?reports_length=50&compare=compare&id%5B1631%5D=on&id%5B1493%5D=on OpenGL Hardware Database - © 2011-2015 by Sascha Willems ) shows no relevant difference. Only me driver is a bit newer. What can I check now?
Regards, JausHanderl
Stefan3D
Looks like your rig works correctly.
Contact the application developer from Magix and send him the report as well, so he cant say it's the graphics driver's fault and sends you back here
Thanks Stefan3D for sharing your knowledge here with us and for helping JausHanderL with this issue.
Best wishes,
Ivan.
Hello JausHanderL ,
Please let me know if the information that Stefan3D provided to you can help you to solve the issue with the OpenGL.
If you need further assistance you can try to post the issue at the following link:
https://software.intel.com/en-us/forums/developing-games-and-graphics-on-intel/topic/281262 Intel HD Support OpenGL 3 and DirectX10.1?
Ivan.
