22899 Discussions
OpenGL Single Buffer Support on i7-3612QM
I am getting crashes and blank screens when NOT using double buffered schemes in C++ windows applications. Is there a reason this is happening?
Changing
pfd.dwFlag = PFD_DRAW_TO_WINDOW | PFD_SUPPORT_OPENGL | PFD_DOUBLEBUFFER;
to
pfd.dwFlags = PFD_DRAW_TO_WINDOW | PFD_SUPPORT_OPENGL; <---- program won't launch
or ( I tested glut as well for fun )
glutInitDisplayMode(GLUT_DOUBLE);
to
glutInitDisplayMode(GLUT_SINGLE); <----- white screen, not even cleared to glClearColor
I also call the proper flush/swap calls. Both of these changes cause issues. Is this a known limitation?
Allan_J_Intel1
I am having this same issue. I have the Intel HD Graphics 4000, and I just downloaded the latest drivers (9.17.10.2875) as you suggested, but it is still happening.
It happens only when PFD_DOUBLEBUFFER is not specified in the pixel format, as Andrew suggested.
I have tried this on other graphics cards, such as NVidia or AMD; the problem does not seem to exist on those, which makes me think that it's a driver issue.
I can point you to some software I have developed that you can use to test this, but I would need to get it to you privately, since it is not publicly available. Please let me know how I can do so, as I would really like to get a fix for this.
Allan, I have downloaded the latest drivers (9.17.10.2932) and the issue still exists. I would really appreciate it if you could help me get some resolution on this issue.
Eric
powerarmour
Valued Contributor II
Eric
Have you tried the 15.31 2885 beta drivers?, I find these are the best for the HD 4000 at the moment, especially for OpenGL applications :-
http://forums.laptopvideo2go.com/topic/24340-intel-gma-drivers/page-15 Intel GMA Drivers - Page 15 - Intel GMA releases - LaptopVideo2Go Forums
Hello, thanks. No, I haven't tried those beta drivers. Why aren't they available from the Intel web site?
powerarmour
Because they are leaked Haswell betas, they are the first of the 15.31 series and come with a newer control panel also (as well as fixing a stack load of bugs!)
Try them, can't hurt , I wouldn't use any other driver on my HD 4000 system to be honest, all of the 15.28 series have been pretty poor so far IMHO, especially for gaming performance/compatibility.
Ok, thanks, but am I missing something? None of the links to that version seem to be valid on the page you posted.
