23854 Discussions
OpenGL error
VinojanT
I am using QT5.15.1 and OpenCascade7.5.0 in my project. When I build the source code and trying to run it, 3D view is not showing, instead it is reporting below error.
My laptop graphics driver is
But same project is working in another laptop with Intel(R) HD Graphics 620 (27.20.100.8681).
Can anyone he me to sort it out?
This is a big issue for me, with this I cannot move forward with my project.
Thanks in advance.
David_G_Intel
Hello VinojanT
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Steps to replicate this problem
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
VinojanT
Hi David G,
Thank you for your quick response.
Still I cannot solve the issue. I created post in Opencascade (With OCCT 7.5.0 build, 3D viewer is not showing up in applications - Forum Open Cascade Technology) forum and waiting for their reply.
Best regards.
Vinojan T.
David_G_Intel
Thank you for the update. If you need assistance from us, please provide the information above or if you want to continue with their support let us know to close this thread.
David G.
David_G_Intel
David G.
VinojanT
Yes, Now my issue is fixed. But I need to use NVIDIA as preferred GPU.
Thank you.
David_G_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
David G
