22690 Обсуждение
PB driver HD graphics with lid closed
scoui1
Начинающий
7 953Просмотр.
With the latest drivers Intel HD graphics, i have a black screen (with the laptop lid is closed) when i'm connect with Dameware Mini Remote Control .
The laptop is plugged in (not in battery).
Is there a setting to disable so that there is no black screen when the laptop lid is closed ?
0 баллов
21 Ответы
Сотрудник
5 097Просмотр.
Hello seb91,
I would like to gather more information regarding your system configuration, this will help get a better look a this situation. Please respond to the following;
Amy.
scoui1
Начинающий
5 097Просмотр.
If i force to remplace The "Intel HD graphics 520" by "Microsoft basic video card", i can connect with Dameware Mini Remote Control (with the laptop lid is closed).
Intel SSU report :
# SSU Scan Information
Scan Info:
Version:"2.5.0.8"
Date:"05/03/2017"
Time:"00:00:35.1444996"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Dell Inc."
BIOS Mode:"UEFI"
BIOS Version/Date:"Dell Inc. 1.12.6 , 07/02/2017 12:00"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.0"
Sound Card:"Realtek Audio"
Sound Card:"Son Intel(R) pour écrans"
System Manufacturer:"Dell Inc."
System Model:"Latitude E5470"
System SKU:"06DE"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"21.20.16.4627"
- "@oem6.inf,%dwmirrordrv% 64-bit;DameWare Development Mirror Driver 64-bit"
Adapter Compatibility:"@oem6.inf,%dameware% 64;DameWare Development 64"
Adapter DAC Type:"Not Available"
Adapter RAM:"Not Available"
Bits Per Pixel:"32"
Caption:"@oem6.inf,%dwmirrordrv% 64-bit;DameWare Development Mirror Driver 64-bit"
CoInstallers:"oem6.inf,DwMirror,Not Available,Not Available"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"DamewareMini.sys"
Driver Date:"03/14/2008 01:00"
Driver Path:"C:\WINDOWS\system32\DRIVERS\DamewareMini.sys"
Driver Provider:"DameWare Development"
Driver Version:"1.1.0.0"
INF:"oem6.inf"
INF Section:"DwMirror"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"@oem6.inf,%dameware% 64;DameWare Development 64"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"ROOT\DISPLAY\0000"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"59 Hz"
Refresh Rate - Minimum:"48 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"DwMirror"
Status:"Degraded"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Not Available"
- "Intel(R) HD Graphics 520"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 520"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520 http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520"
CoInstallers:"oem4.inf,iSKLD_w10_DS,Internal,Intel(R) HD Graphics Family"
Driver:"igdkmd64.sys"
Driver Date:"03/09/2017 01:00"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\igdlh64.inf_amd64_4ac0038ddc82c1c6\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem4.inf"
INF Section:"iSKLD_w10_DS"
Installed Drivers:"igdumdim64,igd10iumd64.dll,igd10iumd64.dll,igd12umd64,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
Manufacturer:"Intel Corporatio...
Сотрудник
5 097Просмотр.
scoui1
Начинающий
5 097Просмотр.
Yes, the issue persists with the driver provided by my computer manufacturer.
seb
Сотрудник
5 097Просмотр.
Thanks for the answer.
I would like to request one more thing before continuing, and that is to test a couple of Intel® HD Graphics old drivers which you can find below;
The reason why I want to get these results is because you mentioned the Microsoft basic driver worked, so with this I want to check if the issue with drivers.
Thank you
Amy.
scoui1
Начинающий
5 097Просмотр.
It works with Beta Intel® HD Graphics .4530 but there is a yellow exclamation mark on the card :
seb
Сотрудник
5 097Просмотр.
Seb, the exclamation mark is jut to indicate that this driver has not been digital singed by Microsoft. Beta drivers are not subjected to this process, only productions drivers.
Amy.
scoui1
Начинающий
5 095Просмотр.
OK, so do you know why these drivers work but not the others?
thanks,
seb
Сотрудник
5 097Просмотр.
It's possible that is related to your power settings; what is the setting you have configured for the lid? In "Power Options" you should find it. Please check if the driver changed any of your power setting for the lid.
Amy.
scoui1
Начинающий
5 096Просмотр.
The power settings not change :
Сотрудник
5 096Просмотр.
seb, please let me look into this.
Amy C.
scoui1
Начинающий
5 096Просмотр.
How do you do that ?
seb
Сотрудник
5 096Просмотр.
seb, I have got some suggestions for you, please find them below;
Amy C.
scoui1
Начинающий
5 096Просмотр.
I tried but it doensn't work.
I have always a black screen if i close laptop lid.
seb
Сотрудник
5 096Просмотр.
Thank you for this information.
seb, I would like to replicate this from my end and I need to know what specific steps you follow in order to face this issue. This will help me to get the same results and to get accurate answers for you.
Amy C.
scoui1
Начинающий
5 096Просмотр.
OK,
We can download Dameware (free trial):
http://www.solarwinds.com/dameware-mini-remote-control http://www.solarwinds.com/dameware-mini-remote-control
When you take control with lip laptop open, there are no problem.
But if you close lip laptop, there are a black screen.
seb
Сотрудник
5 096Просмотр.
Thanks, I will set up my laptop and let you know the results as soon as possible.
Amy C.
scoui1
Начинающий
5 096Просмотр.
Have you try ?
seb
Сотрудник
5 096Просмотр.
Hi seb,
At this stage I have been unable to replicate this matter. Currently there is new driver version that I would like you to test, please find it here: https://downloadcenter.intel.com/download/26836/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88355 Download Intel® Graphics Driver for Windows* [15.45]
Amy C.
scoui1
Начинающий
4 820Просмотр.
I tried but it did the same thing.
seb
Ответить
