22667 Discussions
PlaidML - What does the __k<number> suffix on kernel names in the PlaidML benchmarks mean?
VMaly2
​I was not able to find a forum on PlaidML, so please move or redirect me to correct forum topic if needed
I am working on a National Science Foundation funded research project at CSUS where we are using PlaidML to test our instruction scheduler on AMD GPU's. When profiling the PlaidML benchmarks, I found that the same kernel was appearing many times, but each time followed by a unique suffix in the form of __k### where ### is a number. The same kernel would appear with a different __k suffix, but when examining the ISA code generated by the compiler, only one version of the kernel is compiled. For example in densenet169, kernel_c149_sdk_7 appears with 82 different names. Each name has kernel_c149_sdk_7 in it, but is followed by __k### with different numbers.
What is the significance of the __k## suffix? Are these kernels the same or is there different assembly generated for them?
Thank you for your time.
Stefan3D
