23728 Discussions
Potential Memory Leak in User Mode Driver for Intel Graphics Technology when using OpenGL
ALind15
We are facing a memory leak when using .net Application (.net 4.6.1 C# Windows Forms with OpenTK GLControl) with Intel HD graphics (inside igdgmm32.dll). Our capabilities are limited, can you help further analyzing?
Preconditions
Intel HD Graphics
  • verified with:
  • Intel UHD 630 (Driver: 26.20.100.6911), Windows 10 => igdgmm32.dll
  • Intel HD 530 (Driver: 21.20.16.4542), Windows 7 => ig9icd32.dll
  • Intel HD 620 (Driver: 26.20.100.6888), Windows 10 => igdgmm32.dll
  1. Create Windows Form
  2. Add GLControl (make sure property "Dock" is set to "DockStyle.Fill"
  3. Shrink or grow GLControl on every frame
Note: when removing the dock-style setting, the leak does not occure.
Note: this is not representing the actual usage, this is just to make this issue occur more likely.
Screenshot of growing memory consumption in igdgmm32.dll
Related information
Operating system
  • Windows 10 (OS build 17134.1006)
NuGet:
  • OpenTK 3.1.0
  • OpenTK GLControl 3.1.0
What runtime (.NET Framework, CoreCLR, Mono)
  • .net Framework 4.6.1
ALind15
Below you find a Redgate ANTS Memory Profiler Result ("MemleakTest_ProfilerResults_101819.zip") and a CSharp Test Project ("MemleakTest.zip").
After starting the Test Project, the GLControl (UserControl as a Container for OpenGL Drawings) will start switching back and forth the Back and Front Buffer. By pressing the "s" key, a thread is started to Grow and Shrink this UserControl leading to the described MemoryLeak.
Please let me know if you need any further details or want me to re-transmit the files if outdated before investigating.
Thanks in advance!
Secure File Downloads:
Available until: 25 October 2019
Click links to download:
302.77 KB
MemleakTest.zip
11.18 KB
You have received secure links within this email sent via File Transfer Service. To retrieve the files, please click on the links above.
Leonardo_C_Intel
Hello ALind15
Thank you for posting in the Intel Community.
In order to understand more about this behavior please confirm the following details:
What application is having this behavior?
Are you developing this application?
Leonardo C.
A Contingent Worker at Intel
ALind15
Hi Leornardo,
thanks for your answer.
The application is written in C# (.net 4.6.1). In that application, I use OpenTK as a wrapper for OpenGL (https://github.com/opentk/opentk).
I sent the same request to their board as well in order to isolate the faulty behavior.
I wrote a sample project that shows the described behavior. You can find it attached to my previous comment (MemleakTest.zip).
I hope that helps,
André
Leonardo_C_Intel
Hello ALind15
After reviewing the details on the behavior that you are having I am noticing that you are writing/developing the application, I would recommend referring to our Intel® developer zone (https://software.intel.com/en-us/home) for more detail assistance on this issue.
Leonardo C.
ALind15
I reopened this request on the developer board. Thanks for you assistance.
