Hi, everyone!
My laptop (Acer Aspire E1-570) throttles the package power when plugged in. (From battery everything is OK)
Because of power throttling my Intel HD 4000 doesn't gain needed power so, clock speed goes down and it can't boost.
It maybe laptop doing that for faster charging or also maybe it's Intel's power limitting.
So, how can I disable this power throttling (TDP Throttle)? Because of this I can't play games in minimum requirements.
Note: It's not power options issue, I checked that several tiimes.
And don't confuse it with CPU Clock throttling. CPU clock speed is at maximum. Only Intel HD clock speed goes down due to package power throttling (I think).
Thank you in advance!
Monitoring during FurMark GPU stress testing. As you see the package power is 7W and Intel HD's clock speed is 349 Mhz. But it must be 20 w to be able to boost Intel HD clock speed.
Guess it will help. What is Ring/Package Power Limit Exceeded?
- Tags:
- Acer Laptops
- Laptops
Check out: http://forum.notebookreview.com/threads/tdp-and-power-limiting-haswell.766743/ TDP and Power Limiting (Haswell) | NotebookReview
NB your rig is IvyBridge though http://ark.intel.com/products/72057/Intel-Core-i3-3227U-Processor-3M-Cache-1_90-GHz Intel® Core™ i3-3227U Processor (3M Cache, 1.90 GHz) Specifications
https://www.acer.com/ac/en/GB/content/support-product/4910?b=1 Your BIOS is up-to-date?
Thank you for your reply.
I saw that specifications. And Intel HD 4000 have to boost to 1100 Mhz, But it doesn't.
I'll post this thread in that forum you provide me.
And yes, BIOS is up to date
Also I tried to change my AC power adapter and it didn't help. I think it's intel hd 4000's problem....From battery 1100 Mhz, from AC power not boosting (350 Mhz)...
Stefan3D, thanks for your collaboration.
To: Meschrenz
Hello Meschrenz,
In regard to your concern, please add all the additional information over this thread /thread/110386 https://communities.intel.com/thread/110386.
Please do not hesitate to add any additional information over that thread, in order to give the proper follow up to your concern.
Angie
