23527 Discussions
Problem with dual setup : Intel HD530 (skylake) + GTX970
ASess
Hi everybody and happy new year.
Yesterday i installed my new pc with this configuration :
Intel i5-6600K
GA-Z170-D3HP
DDR4 16Gb 2400
Asus Strix GTX970-4GB-OC
Windows 10 Pro 64bit
All seems works fine, i can extend my desktop to the hd530 . I setted PCIe_1 as default vga in bios
I need to plug at least 4 monitors for use my flight simulator software but if i plug a monitor (i tried with vga connector) to the Intel 530 the sim crash after loading .
If i use only the Nvidia with 2 monitors all is perfect, and sim run very well.
Do you have any idea about this problem?
Thank you in advance
ASess
UP
Allan_J_Intel1
When installing an external video card, the onboard graphics solution is disabled electronically.
You will need a video card with 4 video ports in order to achieve 4 monitor output.
Allan.
ASess
I can use both video card with normal use of pc .
I think to know now why prepar3d (flight simulator software) : the intel530 can have max 512 of shared ram (at least on my system) so simulator crash.
I also was trying to use only hd530 but the sim crash
Allan_J_Intel1
If your computer BIOS gives you any option to change video memory, you can increase it. Otherwise; this will locked by the computer Video BIOS .
Allan.
ASess
Yes there is and the max value for it is 512M.
Regards.
Allan_J_Intel1
In that case, the maximum video memory is 512M as per your motherboard maker BIOS integration.
Allan.
